Old 06-03-2013, 07:46 PM   #1
Roostboy102
Roostboy102's Avatar
Injector questions...
I've come down to firing my 4.8 swap. At first I couldn't get it to start at all. Pulled injectors and they were fullllll of bad gas turned goop or whatever you want to call it. I "cleaned" them (kerosene soak, carb cleaner, boiled in water for 5 minutes) and it worked (for a little bit). After cleaning them it'll start up with a lot of cranking and idle for 3 minutes or so and then just shuts off. I revved it in that time too and it sounded perfect. Then it just dies. It basically will not start for like 10 minutes but if I give it time then it'll pop right off again and run for a while.
Soooo; here is the question: if I get new injectors could I possibly experience the same thing? I'm running a return system with a factory 01 Silverado fuel filter and an external walbro pump with the factory tank.
Where else should I look. I don't want to drop a whole lot of money for new injectors and then I'm back to square 1 after running it for a little. Any help appreciated guys! Gotta thank you all for getting me this far! Before my C10 and the lsx swap, as far as I went with vehicle maintenance was brakes and oil changes. Learning a lot...
72 C10 - Multicolor, 4.8 ls, NV3500. Sold
72 K5 - Under Construction
Roostboy102 is offline   Reply With Quote
Old 06-03-2013, 10:52 PM   #2
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Re: Injector questions...
I bought a set of takeoffs from eBay. Be aware that there are harness differences, and the injectors have different lb/hr ratings so the tune may need tweaking. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 06-04-2013, 04:59 AM   #3
Roostboy102
I plan to get the same part number injectors so I would think that wouldn't be an issue!?
Old 06-04-2013, 10:32 AM   #4
66C06
66C06's Avatar
could be trash in the fuel rails or the lines. How new are the tank and lines? Were the fuel rails and injectors new or used? Try doing a seafoam treatment through the fuel system. It will clean the junk out of the fuel injection system.
66 SWB Stepside: Project C-O6
06 ZO6 MSM 6spd 562/520rw N/A
06 Caddy CTS The Daily
07 Hayabusa - absolute chaos
66C06 is offline   Reply With Quote
Old 06-04-2013, 02:09 PM   #5
Roostboy102
Tank is original but the truck has been driven ever since it was new. Lines are new. Rails came with the engine. I'll try the seafoam
Old 06-04-2013, 02:40 PM   #6
NPilot1975
NPilot1975's Avatar
Did you have the VATS programmed out?
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 06-04-2013, 04:41 PM   #7
Roostboy102
[QUOTE=NPilot1975;6107121]Did you have the VATS programmed out?
Posted via Mobile Device[/QUOTE
Yes, it runs for like 5 minutes perfectly fine and then just shuts off.
Old 06-04-2013, 04:53 PM   #8
NPilot1975
NPilot1975's Avatar
I am pretty sure that is how the VATS works. It lets the engine run for a few minutes then cuts fuel.
Old 06-04-2013, 04:55 PM   #9
NPilot1975
NPilot1975's Avatar
I would check your fuel pressure or if your pump is cutting out
