Old 06-03-2013, 09:29 PM   #1
BBrendal
Recalculating.....
BBrendal's Avatar
Tach advice
So Im adding an original tach to my truck and have a few questions.
1 Im getting the HEI harness from Classic Parts which dimple do I drill out on the firewall to run the wire through? A pic would be great!
2 I want to test the tach before I put it in do I just run a wire to the tach lead on the HEI distributor to the tach and then the other terminal on the tach to 12V?
3 Do I have to do anything different because Im using HEI?
Thanks in advance.
Brian - (BBrendal)
1969 Chevy Camaro Z28
1972 Chevy Blazer CST
2004 GMC Yukon (The truck that pulls the car trailer)
1972 Chevy Blazer CST #2 (Finished and sold!)
Blazer build link...
http://s1213.photobucket.com/albums/...rendal/Blazer/
BBrendal is offline   Reply With Quote
Old 06-03-2013, 09:40 PM   #2
Mister-B
Re: Tach advice
It's really pretty straight forward, especially where you have HEI. I just picked a hole. Not sure if there is a correct one. Don't see any reason why you couldn't test it like you mentioned. Here's my tach installation thread, that should give you a couple pointers
http://67-72chevytrucks.com/vboard/s...ght=Found+tach
Mister-B is offline   Reply With Quote
Old 06-03-2013, 11:40 PM   #3
FirstOwner69
FirstOwner69's Avatar
Re: Tach advice
Try this link... http://67-72chevytrucks.com/vboard/s...d.php?t=439292
I used a Rotabroach to cut the hole. Better than a hole saw and WAY better than a drill. http://www.ebay.com/itm/Blair-Rotabr...ht_2157wt_1043
FirstOwner69 is offline   Reply With Quote
Old 06-04-2013, 12:57 AM   #4
leddzepp
Moderator
leddzepp's Avatar
Re: Tach advice
Make sure it's grounded before you test it, otherwise it will fry.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
