Old 06-04-2013, 12:14 AM   #1
Hawssie
Front seat bracket i.d.
I have three sets of front seats. All seem to be for blazers or at least were mounted in them at one time. My first question are these blue high back buckets original? My second question is about these loose seat brackets. They look to be from a Blazer put they are quite different from my other two. Maybe a different year? The other 2 are from 72s. On the loose set of seat brackets it has hook for holding the pass seat down and has a set of springs, I imagine to help lift the seat.. The other mounted sets don't. Also the drivers side is different too. I didnt put a picture up of that yet but the driver side slide lever comes out under the front part of the seat under your legs while the other two that are mounted have the adjustment ever coming out on the side. DO these look to be from out body style Blazers?
Hawssie is offline   Reply With Quote
Old 06-04-2013, 12:18 AM   #2
Hawssie
Re: Front seat bracket i.d.
I also forgot to point out that the loose set has a totally different lever for popping up the pass seat. Here is a picture of the loose driver side bracket and one from one of the mounted driver side brackets.
Old 06-05-2013, 12:51 PM   #3
RLONG
RLONG's Avatar
The blue seats are not original to 67-72 could be later model van seats.
RLONG is offline   Reply With Quote
Old 10-16-2014, 11:41 AM   #4
EricSean
Active Member
Are you interested is selling the loose set if you still have them. I need a set for the seats I have.
EricSean is offline   Reply With Quote
Old 10-20-2014, 08:44 PM   #5
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Re: Passenger Front seat bracket i.d.
The mounts on the blue seat look like they are '72 Blazer like you mentioned.
The loose mounts look like '78-up Blazer.
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 10-20-2014, 11:49 PM   #6
61Cadman
Would you be interested in selling the brown set.
I'm in Cali too!
61Cadman is offline   Reply With Quote
Old 10-24-2014, 08:25 PM   #7
JimmyFloyd
The front brackets on the 73-77's were slightly higher than the 69-72 I believe. I agree that the one with the hook is 78+
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 10-24-2014, 11:13 PM   #8
badpeanut
badpeanut's Avatar
You are correct. In addition the '73-'77 have a spring assist like the '78-up.
'70 GMC LWB trailer
