Old 06-04-2013, 07:00 AM   #1
JFetter
Parking brake nightmares - Everything is missing??
Hello,
It seems one of the PO's has removed every component of my parking brake system. All the brackets, cables etc.
I've seen the layout on LMC's catalog, but other than that I have nothing to go on as far as rebuilding this.
What really concerns me is the frame brackets/cable routing brackets. So far none of my local salvage yards have trucks this old anymore.
I've noticed the 73-83 Parking brake setup looks quite complicated compared to the 84-87. Since I'm building from the ground up anyway, could I convert to that newer style? I would still need to procure, or make, frame brackets though.
Looking for some guidance on the best route to take.
Thanks!
1978 K10
JFetter is offline   Reply With Quote
Old 06-04-2013, 08:09 AM   #2
Greenlee
Greenlee's Avatar
Re: Parking brake nightmares - Everything is missing??
I just got mine working. It's the newer 84-87 style. One thing I learned is the factory cable seemed to be three separate sections of cable (rear, middle and front). I was only missing the middle section and couldn't find it anywhere. However, I bought a replacement cable at O'Reilly's and it replaced the two front sections of cable. Also, the first cable they sold me was too long. There are different lengths for short bed and long bed.
When I finally got the right cable it went in pretty easy and works great.
I wasn't missing any brackets. I don't think the newer style has as many brackets as the old style.
Greenlee is offline   Reply With Quote
Old 06-04-2013, 08:17 AM   #3
JFetter
Thanks for the info.
I forgot to mention, that I have a Short Bed.
1978 K10
Old 06-04-2013, 09:31 AM   #4
wraprail
wraprail's Avatar
Same problem here. I'm thinking of trying the Jamar Park Lock.
Anyone use one before?
http://www.jamarperformance.com/Onli...8o7gqbm15gqf50
wraprail is offline   Reply With Quote
Old 06-04-2013, 09:43 PM   #5
JFetter
wraprail - your link isn't working for me
UPDATE: After getting more light and looking under the truck, it appears that I DO have at least the two rear-most cable brackets. (the brackets right before the rear wheels. They each have 2 bolts holding them to the frame)
I appear to be missing the Middle brackets though- unless they are just for long bed trucks??
See picture here
http://www.lmctruck.com/icatalog/cc/865w/0166.jpg
The 2 brackets I'm missing, are between parts #5 and #8 on the diagram. Approx mid length on truck.
1978 K10
Old 06-04-2013, 10:58 PM   #6
SamsAutoParts73-87
SamsAutoParts73-87's Avatar
My 87 has a line lock which is similar to what is being offered on the link. Mine will hold the truck in place on a hill while I'm loading another truck on the bed but according to my owners manual it should only be used in combination with the factory parking brake.
Not that I'm saying it won't work, just sharing the info.
-Sam
1987 Chevy R30 CC 454/4spd Work Truck
1979 Chevy K10 SWB 350/4spd/NP205,
1979 Chevy C10 LWB 350/TH350 Project
1981 Chevy K30 350/Th400/NP205
1986 Chevy K30 CUCV 6.2L/TH400/NP208
SamsAutoParts73-87 is offline   Reply With Quote
