Old 06-04-2013, 02:19 PM   #1
skip99
skip99's Avatar
sway bars front rear combo?
hopefully someone has already experienced this, or at least has a better idea than me !
52 chevy truck, must II front, leaf spring 8.5 rear. 350/350.
want to get a front sway bar. jpl streetrods has one , says it is 7/8"
and i have a choice of 15mm (5/8), 17mm(11/16), 19mm.(3/4)....
camaro bar for the rear,,,
which would you reccommend for the rear?
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 06-04-2013, 07:52 PM   #2
LONGHAIR
Re: sway bars front rear combo?
I suppose it would depend upon which one you use up front. Balance is the key, if you over-do either, it can have a negative effect.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-04-2013, 08:54 PM   #3
skip99
skip99's Avatar
Front is 7/8...... I have a choice on rear, I'm thinking 5/8 is better for rear since its smaller
Tami's 51 build
Old 06-04-2013, 09:38 PM   #4
LONGHAIR
Have you driven it with just the front yet? You may not need it. The rear bar would only be helpful if you had too much oversteer.
Old 06-04-2013, 09:47 PM   #5
skip99
skip99's Avatar
Thanks for the replys, but I was kinda hoping someone has already added, removed, or whatever..and can suggest which, haven't driven it yet, just wanting to do all the fab suff first.
So, If I add a 7/8 bar to the front, on a 52' mustang 2 front, nova rear, leaf spring. ..
What do you suggest for the back? Nothing? Or a 5/8 rear bar, or larger?
Tami's 51 build
Old 06-05-2013, 12:00 AM   #6
oldman3
oldman3's Avatar
skip99, I'm running the same setup your talking about. Mine's a 50 with Mustang II front with coilovers, GM brakes, 74 Nova rear axle on aftermarket leaf springs. I have a 7/8" bar up front with nothing in the back. I live in the Ozarks with lots of hills and curves and I've had no problems with the truck. Truck handles well and rides good. You can check out my build for pics on the install....Jim
oldman3 is offline   Reply With Quote
