Old 06-04-2013, 02:19 PM   #1
Erl
Erl's Avatar
Gas Signal Wire Thru Firewall. Where?
I moved my gas tank from behind the seat to under the bed. I am running a new Blazer sending wire and would like to know where to penetrate the firewall. Is it the same for Suburban and Blazer?
Erl
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
Old 06-04-2013, 03:04 PM   #2
luvbowties
luvbowties's Avatar
Exclamation Re: Gas Signal Wire Thru Firewall. Where?
Why not run it thru a hole behind seat(thru floor) and then underneath carpet or sill mldg. to dash area?--small hole/small plug! No safety issues--it's merely a ground, right?
Sam.
luvbowties is offline   Reply With Quote
Old 06-04-2013, 07:51 PM   #3
JimKshortstep4x4
The Suburban wire to the sending unit goes up the A pillar and follows the roof edge to the rear, through the floor and to the tank. Not sure where the Blazer wire runs but it is not like the Burb.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
