Old 06-04-2013, 04:37 PM   #1
musicfan4322
Horn Problems
I have been having problems with my horn for about a week now. The other day with my 72 C10 was off sitting in the garage and the horn began going off. I disconnected the horn and the next time I went out to my truck the battery was dead. I charged the battery and began trying to figure out the problem with my horn. I changed the horn relay and the problem did not go away. I disconnected the horn button and connected everything else up and the horn still went off on its own. What could cause this problem? If your answer is a short what is the best way to tackle this type of issue from a short?
musicfan4322 is offline   Reply With Quote
Old 06-04-2013, 04:48 PM   #2
cdowns
cdowns's Avatar
Re: Horn Problems
your horn wire inside your steering column is shorting out causing the problem
Old 06-04-2013, 05:26 PM   #3
musicfan4322
Re: Horn Problems
do I need a horn puller to get it there
Old 06-04-2013, 05:47 PM   #4
Daner
Daner's Avatar
Re: Horn Problems
http://67-72chevytrucks.com/vboard/s...d.php?t=560844
Try this thread.
It shows how the switch stuff goes together. If the wires are the problem then you will probably need a puller.
Dane
67 Chevy Fleet 250/4 speed 1/2 ton
68 Chevy 250/4 speed 1/2 ton for parts
49 GMC Grain truck 235 1 1/2 ton
76 Chevy 350/4 speed 1/2 ton
Daner is offline   Reply With Quote
horn going off on own
