Old 06-26-2003, 05:02 PM   #1
slomotion
Old Duffer
slomotion's Avatar
Dually wheels
I did a search a couple of weeks ago concerning dually wheels on a '68 C20. There was some discussion, but I never saw, (or missed) what type of wheels will fit my truck.
It currently has a tube-type 16" wheel (not exactly a split-rim but not a regular steel wheel either. Sorry I don't know the correct name for the type.) What I would like to do is run a set of radials but these wheels won't do it.
The wheels are 16" with a 4 1/2 inch center pilot hole, and 8 lugs with a 6 1/2 inch bolt pattern. Is there an after-market wheel or (ah-hmm) another brand wheel that will fit?
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 06-26-2003, 08:52 PM   #2
da-burb
"Ochre Ogre"
da-burb's Avatar
are you sure it is 4-1/2". I think you will find it is 4-5/8. Your 68 will have smaller diameter studs than the 1970-71 and up trucks. You should only have to drill out the opening and install the larger studs. (I am thinking you have 1/2" dia studs and they went to 9/16".) I used 2001 wheels on my 1971 C30 and I know others have used late 90's Ford alum wheels too.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 06-27-2003, 03:49 PM   #3
slomotion
Old Duffer
slomotion's Avatar
Thanks Da-Burb! Now that I know where to start looking I might make some progress. You're right, the pilot hole is 4 5/8...when I measured the front it was a toss-up as to which dimension to use (4 1/2 or 4 5/8) because there's a lot of paint on these things!
Thanks again
and WC T5 trans.
'81 G10 Shorty Van
Old 06-27-2003, 05:21 PM   #4
da-burb
"Ochre Ogre"
da-burb's Avatar
BTW, plain steel dually wheels were $42 each for brand new. I found my set of 7 new wheels for $200 and it came with new trim rings, new lug nuts, and bright lug nut covers.
