Always a work in progress
Is this ball joint installed right?
85 C10 CPP 2.5" drop spindles, 2" drop springs, poly bushings.
So I thought I had an issue with the control arm bc the ball joint was going in and out of the hole. So I bought a control arm new moog ball joint and bushings to fix the problem. The ball joint went in the control arm like it should same with the bushings. I got everything installed and was putting the ball joint through the spindle and it didn't seem to go in the hole far enough. It just didn't look right, but I can put the cotter pin through the ball joint with the nut on, but it just doesn't look right. Pic: ![]() Posted via Mobile Device
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
| Bookmarks |
