Old 06-04-2013, 08:29 PM   #1
Codez67Chevy
Codez67Chevy's Avatar
Kinda Depressed
So today after work I finished up some work on the chevy. Decided to finnaly pull it out of the garage after a year of not running under its own power. So I did!!! Yay!!! And then it happened the radiator started to leak and now its back in its hole. I was going to show you all my truck but I can't yet because just as soon as I was going to snap some pics the leak happened. So tomorrow gonna pull the radiator fix the little problem and hope it can roll out once more. Thanks for listening to me rant.
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses".
93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+
Members I've met...
Mister-B
Codez67Chevy is offline   Reply With Quote
Old 06-04-2013, 08:43 PM   #2
zeeklu
Re: Kinda Depressed
If thats the biggest problem your doing good. Should be an easy fix.That's no excuse for no pictures. JK. Good luck
zeeklu is offline   Reply With Quote
Old 06-04-2013, 08:54 PM   #3
Codez67Chevy
Re: Kinda Depressed
Yea thanks. I'm thinkin it's the drain plug. I bought it used. I filled it a couple of times to make sure that it wouldn't leak but under heat and pressure it could have cracked or just broke loose. We will see tomorrow.
Members I've met...
Mister-B
