Old 06-26-2003, 05:12 PM   #1
Custom 68
Custom 68's Avatar
canister type oil filter to spin on type conversion
I have on older 327 years ago I converted it to the spin on type well I am currently rebuilding it and need the gasket or o-ring or what ever goes into the hole before my converter goes in. I went to the local autoparts store and they sold me a felpro kit with several gaskets and o-rings in it some I believe for an external oil cooler? These all seem too small. What do I need to ask for or does someone have part numbers or what did you do? I am pretty sure it will leak without something???
help...
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 06-26-2003, 09:23 PM   #2
toms68cst
toms68cst's Avatar
I just converted mine to a spin-on when I finshed my rebuild recently. Which hole are you talking about that needs an O-ring? I didn't have to use any extra O-rings for the new filter. The old cannister had an O-ring though.
BTW, Do you still have the old oil filter bypass valve left over from when you converted to a spin-on? Mine was cracked and they are very tough to come by.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 06-27-2003, 09:11 AM   #3
Custom 68
Custom 68's Avatar
Thanks Tom
I will go in and ask for the old cannister o-ring they should be able to find that. I am will look in my stuff but I swapped 327'2 out 15 or so years ago and I believe I swapped the whole thing out from one to another.
Dave
Old 06-27-2003, 01:39 PM   #4
toms68cst
toms68cst's Avatar
I don't think you should need a cannister O-ring. The top of the spin-on filter has one already glued to the top of the housing.
When you buy a new cannister type filter they normally com with a new O-ring.
