Old 06-05-2013, 12:13 PM   #1
jks67ss396
anyone use one of these for steam port?
Guys
Im trying to figure out my steam port vent routing. A lot of guys just tap into water pump (but if wp goes out, gotta do that again... in parking lot of oreillys ) and some guys run this tee from jags that run. and that looks like a nice piece, but then you see it up front right when you pop the hood.
I know that the trailblazer ss's come from the factory with the steam port entering the water pump inlet. So i was thinking of using a tee right there. it wouldnt be as visible as the upper radiator tee and its cheaper...
my steam port vent hose is 5/16" and this tee is 3/8" but that should work.
anyone ever use one of these? dorman 47112
http://www.oreillyauto.com/site/c/de...&keyword=47112
jks67ss396 is offline   Reply With Quote
Old 06-05-2013, 04:13 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: anyone use one of these for steam port?
I used a smaller brass piece to tap mine into the heater core lines, which is pretty easy to do.
As for having to tap it in an oreilly parking lot; thats what the gold AAA card is for.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-09-2013, 03:33 PM   #3
High ho silverado
High ho silverado's Avatar
My radiator had a screw in fitting for the heater hose I jus bought brass fittings and a barb fitting and ran it into there along the upper hose as the stock hose runs across my fan shroud. Not sure if this is a no no or not but seems to work fine. If u need pics let me know.
Dan G
Lift it, fat chicks cant jump!
83 Chevy shortbed 4x4: 6.0 ls powered
97 Chevy 3/4 ton ex cab 454: work horse
00 Chevy camaro: daily driver
83 Chevy 3/4 ton: dads old rig
High ho silverado is offline   Reply With Quote
Old 06-09-2013, 08:47 PM   #4
Dustytrix
BR3W where did you find the brass tee?
Dustytrix is offline   Reply With Quote
Old 06-10-2013, 09:09 AM   #5
Wasted Income
Boosted Member
Wasted Income's Avatar
Originally Posted by jks67ss396 View Post
Guys
You are over-thinking it. I did everything I could to aid in servicability of my swap, but I still tapped the pump.
I've been around enough LS engines to know that the water pumps last foreeevvvverrrrrr. I'm not at all concerned that the pump will puke on a roadtrip and that it would ever be an issue.
$.02
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 06-10-2013, 02:16 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Parts store, the heater lines are small enough that they don't require a special over size tee.
