Old 06-05-2013, 12:58 PM   #1
robber grin
Pitted Perches
Anybody got any suggestions for the 62 frame cab mount perch where the rust attacks under the rubber bushings?
I can still see the diameter of the old stuff in the pattern of rust on each perch.
Nothing is rusted through - just pitted.
Thought about welding washers over each spot.
Any other ideas?
Thank you - rg
robber grin is offline   Reply With Quote
Old 06-05-2013, 01:26 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Pitted Perches
I just removed as much rust as I could with a wire wheel. I treated, prepped and painted the area.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 06-05-2013, 01:30 PM   #3
padresag
Re: Pitted Perches
Any other ideas?
Thank you - rg
just cut out the bad part and out in new material and I used a holesaw to make the holes. they don't get rusted all of the way thru but they do get badly dished out
ron
padresag is offline   Reply With Quote
