06-05-2013, 08:59 PM | #1 |
15x8 inch rally w/4.25 backspace
hey guys,
According to my beer math they will fit on my 55 with a 10 bolt, approx. stock width....I am trying to run a 275-60....any one with experience...? |
06-06-2013, 06:46 AM | #2 |
Re: 15x8 inch rally w/4.25 backspace
A 275 tire is 10.8" tread width that's pretty wide for an 8" wheel.
You should try to keep wheel width and tread width as close as possible. Don't forget to factor tire bulge into your beer math too. I bet a 275 is close to 13" wide sidewall to sidewall. How wide is fender opening to bed wall? Posted via Mobile Device |
06-06-2013, 07:38 AM | #3 |
I ran 275-60-15 tires on 15x8 wheels for a few years on my 59 fleetside. They had 4" back spacing on a stock width rear. I did not have any issues.
___________________________ 1959 Apache Short Fleetside, 1959 Apache NAPCO Long Stepside, 1957 3100 with 59 fleetside bed 1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370 1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF 1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker Big Bertha Build |
06-06-2013, 08:21 AM | #4 |
I have 275/60/15 on the rear of mine, on a factory 4x4 (80's k10) rally wheel. Its a little snug in the rear. My bed is a fleet, which i believe is wider than a step
06-06-2013, 11:19 AM | #5 | |
06-06-2013, 11:20 AM | #6 |
06-06-2013, 01:36 PM | #7 |
I had 275/60s on the back of my 55 on 8 inch rallys, they rubbed on the fenders. I put 255/70s on it and they worked ok.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
06-06-2013, 03:08 PM | #8 |
Thanks. The folks at Discount tire (Locally) said the could mount the tire on the rim and test fit it and if does not work we could change to another tire (no charge for tire if it does not work). So I will keep the 255/70 in mind.
06-07-2013, 11:12 PM | #9 |
I'm running 245r65-15's on Corvette AZ code 15x8 ralleys (4" offset) on a Camaro 10 bolt and they are 1/2" from the bed and 3/8" from the fender. I have some light rub marks on the bed from cornering too! I was told the Corvette had the 4" offset and the 4.25" offset is from the Camaro?!?
06-08-2013, 07:19 AM | #10 |
I have 275/60R15 on the rear of mine..
06-08-2013, 04:09 PM | #11 | |
