06-05-2013, 10:46 PM | #1 |
How do I shorten turning radius on 69 C10
Recently installed power steering and when I make the max turn I get a noise that I think is the PS steering unit telling me it wont go any further. How do I get more turn or tighter radius for a turn with hitting the PS limit?
Posted via Mobile Device Posted via Mobile Device |
06-06-2013, 02:42 AM | #2 |
Re: How do I shorten turning radius on 69 C10
Conversion.... where did the parts come from???
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
06-06-2013, 03:26 AM | #3 |
smaller tires give tighter turning radius
06-06-2013, 05:28 AM | #4 |
Turn the wheel all the way and give it lots of gas
06-06-2013, 09:01 AM | #5 |
06-06-2013, 09:53 AM | #6 | |
Active Member
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
06-06-2013, 08:20 PM | #7 |
I got the gear box from POL. Parts On Line in LA
06-06-2013, 08:23 PM | #8 |
I have been thinking of replacing my 3:08 rear end with of a 3:72 POSI. Why do you say it is even more fun with a POSI?
Pitman is stock Pitman. Posted via Mobile Device Posted via Mobile Device |
06-06-2013, 09:16 PM | #9 |
My concern is your replacement steering box may have internal stops for a different application. Is the radius about the same as before or larger after the swap?
08-09-2014, 04:04 PM | #10 |
But Found Her 25yrs Later!
I had a similar issue when I upgraded to power steering on my 66.
I have since sold it. But one thing I noticed was the pitman arm was a little shorter on the power box than the one on the manual box.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
08-09-2014, 04:20 PM | #11 |
Use a steering box from a 73 or newer it will turn lock to lock in 3.5 turns where as what you have is 4.5 turns.
08-09-2014, 05:13 PM | #12 |
A box from a different application will have different internal stops.
A couple people above talked about the number of turns lock to lock. That's really not relevant, as it just describes the internal gear ratio and mechanical ratio of the pitman arm and so on. A different number of turns at the steering wheel has nothing to do with how far the front wheels turn.
08-09-2014, 07:13 PM | #13 |
When the system is designed correctly as the factory did it the steering stops are designed into the control arms, not in the steering box. You never want to bottom out the gearbox before you hit the steering stops, that would be hard on the box internally. I have serviced many gearboxes on gm trucks and noted more travel out of the box on the bench than when it was installed in the truck, that is normal and proper.
08-09-2014, 07:18 PM | #14 | |
Can you explain the pressure relief valve and how it works? I assume it was related to the internal stops, and not external contact. Otherwise wouldn't you be able to put your wheel against a curb and invoke the pressure relief? I'm not going to try that because I have nice wheels though. Is it as simple as when the box encounters an obstruction it jacks the pressure, overrides a spring, and lets the fluid bypass? I had assume that could only happen at the box's internal stops. I have never had a box apart, and only have an approximate understanding of ball bearings and sector gears and whatnot, so go easy on me!
