Old 06-06-2013, 12:59 AM   #1
1966FLEETSIDE
1966FLEETSIDE's Avatar
rear main seal
do i need to raise engine to change rear main seal?i have an original 327 on my 66
1966FLEETSIDE is offline   Reply With Quote
Old 06-06-2013, 06:35 AM   #2
chevyrestoguy
chevyrestoguy's Avatar
Re: rear main seal
If memory serves me right, you should be able to remove the pan with the engine still in the mounts. I haven't done this job in a '60-'66, but have done it a '67-'72 and they should be pretty similar.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 06-06-2013, 12:56 PM   #3
Red65C10
Red65C10's Avatar
Re: rear main seal
I did it with the engine still in. I did raise the engine some after breaking the mounts loose at the frame. It's still tight but can be done. Mine is a 350.
Hope this helps.
Billy
65 C10
............................... ____
................ ________-|___\____
.;.;;.:;:;.,;.|__(O)___|____/_(O)|
_______________________________
P.S. Send truck money !
Red65C10 is offline   Reply With Quote
Old 06-06-2013, 02:21 PM   #4
Rufton
Re: rear main seal
Sorry, unrelated jabber:
I can de-pan 1966 305E V6 w/o touching mounts. I did drop oil pump and had to clock crank to free pan. The 305E main seal is recessed deep (pan flange is flat all around). I wouldn't wanna try replacing 305E seal w/o removing crank. Of course other engines w/ half moon pan flange and 2 piece seals are sometimes easy to change.
Rufton is offline   Reply With Quote
Old 06-06-2013, 07:55 PM   #5
TxRat
TxRat's Avatar
Re: rear main seal
No, I just did the rear main on my 66 327. you may have to roll the crank some to clear the counter weights. I did not raise my engine at all. You'll have to drop the pump so the pan can clear the cross member and pump. Make sure you use the white shims that come with the rear seal so you don't shave the seal. Also oil up the seal before you put it in and clock the seal so the seam isn't flush with the rear main cap mating surface. one last thing, Put a little grease on the lip prioir to installation so you don't smoke the seal on initial start up. and retorque the rear cap!!!
TxRat is offline   Reply With Quote
Old 06-06-2013, 09:34 PM   #6
Lugnutz65
Lugnutz65's Avatar
Re: rear main seal
The above advice got me to thinking. I just installed a rear main seal (different engine) and saw a very thin (thin as paint) shaving of seal material come off the seal as I pushed it in. Do you think I need to buy a new seal and do it again? My kit didn't have any shims. "Clocking" the seal makes sense too and is something I didn't know about. Now you've made me nervous!!!!! LOL!
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 06-06-2013, 09:46 PM   #7
Rufton
Re: rear main seal
I wouldn't redo if pan installed. Fresh seal should respond well to seal conditioner. Was old seal hardened and brittle?
Old 06-06-2013, 09:55 PM   #8
Lugnutz65
Lugnutz65's Avatar
Re: rear main seal
Engine is still on the stand and the pan is off. I can get a new one in in under 10 minutes. The old seal was hard. I'd sure hate to have a leak. The new seal felt VERY snug as I slipped it in and I used RTV where it mates to the other half.
Old 06-06-2013, 10:11 PM   #9
Rufton
Re: rear main seal
In that case I would invest the 10 minutes.
Old 06-07-2013, 12:24 AM   #10
1966FLEETSIDE
Re: rear main seal
geez seems kinda difficult,i never done that before.but i guess thats the only way i will learn.
Old 06-08-2013, 01:00 AM   #11
1966FLEETSIDE
Re: rear main seal
thx txrat .did it stop the leak.i was told some seals keep on leaking after you change them.on this particular type???
