Old 06-06-2013, 01:21 PM   #1
CGerow
CGerow's Avatar
Frame question
Probably been asked here before, but here goes. I have a beautiful 71 Cheyenne LWB that I have owned since forever, and I always secretly wished it was a SWB......my question is, are all the frames from a 71 C-10 the same and just a different length? If I wanted to retain the integrity of my truck, would I be better off to put everything on a SWB frame, or could I shorten up my LWB frame? To me the shortening of an existing frame seems like a bad idea? I assume this has been discussed before, and probably done a thousand times, just looking for some thoughts either way.
Thanks from north of the 49th,
Cam
CGerow is offline   Reply With Quote
Old 06-06-2013, 01:32 PM   #2
CGerow
CGerow's Avatar
Re: Frame question
I should have also asked....are the frames different from 67-72?
Old 06-06-2013, 01:35 PM   #3
tlcrz1972
tlcrz1972's Avatar
Re: Frame question
Leave her a long bed, I have both and prefer the ride and useability of the longbed. It's not worth the trouble to cut and hack IMO.
tlcrz1972 is offline   Reply With Quote
Old 06-06-2013, 01:59 PM   #4
Shyguy
Junior Member
Shyguy's Avatar
Re: Frame question
If I could only have one truck it would be a lwb since it is more useable for what I use a truck for.
When we decided to build a swb stepper we bought a '69 swb frame and put the the '67 cab and front clip on the '69 swb frame. I picked up a swb stepper bed in great shape reasonable and used it.
I bought a '75 C-30 dually to used around here on the farm.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 06-06-2013, 02:02 PM   #5
cdowns
cdowns's Avatar
Re: Frame question
lots of guys loudly jump on the hack and wack bandwagon
when they end up as abortions and or in the dumpsters not so loud even more quiet when they dump it off to an unsuspecting sucker
see those guys who throw thier money at shiney truck really start cryin on here when they finally crawl under a truck and find the real dirty truth
Old 06-06-2013, 02:39 PM   #6
SS Tim
SS Tim's Avatar
Re: Frame question
From a strength and actual material cross section consideration the frames are the same. It is a lot of work to cut it correctly under the cab for a 12" shorter wheelbase and a 20.14" shorter bed.
C Blazer
C10 115"
C10 127" 6.04" height 2.53" flange width 0.156" thick 2.98 section modulus
SS Tim is offline   Reply With Quote
Old 06-06-2013, 03:00 PM   #7
70c10longbed
Re: Frame question
Measure twice cut once, square the frame, weld your seams. Not difficult.
70c10longbed is offline   Reply With Quote
