Old 06-06-2013, 01:39 PM   #1
1967Chevrolet
1967Chevrolet's Avatar
Painting with metallic paint
Painting my 67 chevy sometime this week and i was just wondering if anyone had tips and advice for painting with metallic paint, thanks for the help
1967 Chevy K/20 shortbed fleetside 355SBC 4 speed transmission 6 inch lift metallic blue paint (fully restored)
1970 Chevy K/30 8 foot flatbed 350SBC 4 speed manual 8 inch lift faded red paint (fully restored)
1965 Chevy C/10 shortbed stepside 355SBC 4 speed muncie dark metallic green paint (in progress)
1967Chevrolet is offline   Reply With Quote
Old 06-06-2013, 02:06 PM   #2
cdowns
cdowns's Avatar
Re: Painting with metallic paint
i always put 3-4 ballbearings in the paint cup to help keep the paint mixed good and shake to keep the metallic is suspension
Old 06-06-2013, 02:09 PM   #3
Rufton
My advise is to avoid single stage metallic unless you've got talent.
Rufton is offline   Reply With Quote
Old 06-06-2013, 02:13 PM   #4
1967Chevrolet
okay never thought of that before, how much over lap would you recommend because i have heard that metallic paint is easy to tiger strip
Old 06-06-2013, 02:14 PM   #5
1967Chevrolet
we got the base coat clear coat metallic
Old 06-06-2013, 02:27 PM   #6
Rufton
Good call.
You can concentrate on laying metal even and deal w/ gloss later.
With single stage you are balancing glitter and gloss at the same time; you wanna mist but if you do then may have to break out the buffer.
Where's my english teacher?
Old 06-06-2013, 02:35 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Lots of good advice in the paint and body forum. Not as many viewers but you will find some good pointers.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 06-06-2013, 02:59 PM   #8
Rufton
Few thinks I like:
Hold gun working distance from test panel. Horizontal pattern. Squeeze trigger breifly. Verify coverage same from left to right. Squeeze till runs. Should run same time left to right.
Must mix metal frequently like cdowns said. I'll give cdowns good idea bearing mix a go next time.
Except for touchup I like fluid flow adjust set wide open. If choke fluid flow too much spray quality will suffer.
Old 06-06-2013, 04:30 PM   #9
1967Chevrolet
Thanks found alot of useful advie in the paint forums, just had on last question, all the panels are bolted on the truck are you supposed to walk the lenght of the truck while paint then go back, on paint a panel at a time
Old 06-06-2013, 07:05 PM   #10
Rufton
Much easier to paint a panel than entire vehicle. Make sure you have same color substrate and enough color coats or else mismatch. I try to walk at even (not slow) pace for proper coverage when spraying vehicle.
Old 06-06-2013, 07:36 PM   #11
bigbadchev72
People know me
bigbadchev72's Avatar
I do mine in sections/panels. Always keep a wet edge, stir it frequently, make sure you give it enough time to flash between coats, otherwise you will be using way more paint than you need to. on the final coat I hold the gun about 18" away and give the entire panel a "mist" coat to get the metallics even and it will help with tiger striping. It is very important that you do this.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
