Old 06-06-2013, 03:11 PM   #1
Budman56
Budman56's Avatar
Guage cluster question
Short of installing the gauge cluster into my truck and having all the wiring done and ready to fire up, is there a way to check all my gauges to see what works and what doesnt? I have the gauges all tore apart and I am re-finishing the cluster, so I would like to see what works and what doesnt. Anyone have any suggestions? thank you in advance.
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 06-06-2013, 03:36 PM   #2
1963c-10
1963c-10's Avatar
Re: Guage cluster question
The oil pressure gauge is mechanical and has to have the pressure to work. The fuel & ammeter can be checked electrically. Im not sure about the temp gauge. I do not personally know how to check them electronically off a bench, but Im sure that someone here can and will help. I just know that they can be bench tested.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-06-2013, 03:51 PM   #3
Budman56
Budman56's Avatar
I would assume that I could wire a 12volt source to the back of the gauges and test them but I dont wont to burn them out.
MY 65 C20 BUILD
Old 06-06-2013, 04:34 PM   #4
1963c-10
1963c-10's Avatar
I would say post in the electrical section or wait for a response here. The fuel guage works of 0-30ohms, and Im not sure how to bench test it. I would assume 12v source for the ammeter would work though.
