Old 06-06-2013, 04:56 PM   #1
Brad54
Brad54's Avatar
Rear Sway bar options?
Looking for info on rear sway bars for our trucks... actually '60-'72.
What are some companies that make rear bars, and how do they attach to the truck?
Even a list of companies that make them, and/or some installation instructions would work.
I went to Hellwig's site, but it was slow and borderline useless.
Thanks,
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 06-06-2013, 07:17 PM   #2
john
member #16
john's Avatar
Re: Rear Sway bar options?
Here's some info to sift through.
http://www.google.com/custom?domains...D%3A1%3B&hl=en
john is offline   Reply With Quote
Old 06-06-2013, 08:51 PM   #3
FirstOwner69
FirstOwner69's Avatar
I Googled "Hellwig" and found this link for a seller in addition to the Hellwig site. It has Hellwig and another brand. Maybe it'll help.
http://www.suspensionconnection.com/...ry=Sway%20Bars
I put a Hellwig rear bar on my 69 in 1971 and took it off when I started my restoration a couple years ago. I bought it to help handle the large cab-over camper. I won't be using it again.
FirstOwner69 is offline   Reply With Quote
Old 06-07-2013, 12:38 AM   #4
Brad54
Brad54's Avatar
Thanks guys.
Someone told me there's one that attaches by the shock mounts, or that area. Anyone seen that?
-Brad
Old 06-07-2013, 08:13 AM   #5
Bigdav160
Bigdav160's Avatar
Then there are threads like this where people have used camaro sway bars. I'm just not sure which year.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 06-08-2013, 11:01 AM   #6
ezstriper
ezstriper's Avatar
addco is another who makes bars
ezstriper is offline   Reply With Quote
Old 06-08-2013, 12:34 PM   #7
BossHogg69
motor exploder
BossHogg69's Avatar
I haven't looked to see if Addco makes a '60-72 rear bar, but I've used their rear bars on two different trucks ('92 C1500 & '05 Sierra 1500) and the installation was pretty straight forward with very good instructions. It's probably worth the time to just give them a call.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 06-08-2013, 01:40 PM   #8
midniteblues
midniteblues's Avatar
i have this one i pulled from a 2wd 78 square blazer at the jy of course the blazer had leafs an i tried fitting this one too my coil spring suspention forwards reverse up side down and i just cant get it too work properly
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 06-08-2013, 01:49 PM   #9
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Looks like Addco makes a 7/8 inch bolt on rear bar for our trucks.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 06-08-2013, 01:55 PM   #10
Harpie
Harpie's Avatar
I have cpp's rear swaybar on my 71 and it just bolted on was really easy and a very nice product.
Harpie is offline   Reply With Quote
Old 06-08-2013, 04:57 PM   #11
leddzepp
Moderator
leddzepp's Avatar
The rear sway bar that cpp sells is Addco. It is USA made and a nice product. Summit Racing has the best price on them I have found.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 06-08-2013, 05:39 PM   #12
JOJABOY
Are they only for coil sprung rear ends....or does Addco make one for leaf spring set ups also?
JOJABOY is offline   Reply With Quote
Old 06-08-2013, 06:03 PM   #13
Bigdav160
Bigdav160's Avatar
This one says for "leaf spring only"
I like to see one installed. Does it install behind or in front of the axle?
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 06-08-2013, 08:10 PM   #14
hayhauler71
hayhauler71's Avatar
Here is some pics of my Addco rear bar
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 06-09-2013, 05:16 AM   #15
skorpioskorpio
The coil versions seem to mount to the flats of the factory trailing arms, I'm planning on using the Porterbuilt tubular arms is there a sway bar that would easily work with those?
skorpioskorpio is offline   Reply With Quote
