Classic Intsruments Gauges
Has anyone used these gauges from classic intruments? My truck only came with the speedo and fuel gauge cluster, then I installed water temp and oil pressure. I have beefed up my motor now and need to have a tach and would rather have it in the cluster like this. I chose this one because Id like to have them all on the same cluster to monitor them easily. Now Id like to switch to this setup and was wondering if anyone had any comments on the difficulty of the setup it was to install. It says that it comes will all sending units, wiring and wiring for the turn signals, do you think that I will run into any problems? Any comments or suggestions would be appreciated.
This is the link to it on summit. http://www.summitracing.com/parts/ci...ckup/year/1972 And this is the one I am thinking about getting.
1972 C10, used to be daily driven and hoping to be that way again at some point. |
Re: Classic Intsruments Gauges
I used them in my build, I had never messed with anything like this before but the instructions were great and the customer service was some of the best I have ever seen.
Dakota Digital also has some nice set ups as well
Rex |
i used them for my build, very nice gauges and look great ,they have a gauge that is very close to factory,old look with new style sending units mine has a 8k rpm tach
Did you get them from summit or another dealer?
motor exploder
I got mine from board member '55BelAirTim' - he was a supporting vendor at one time and he was way cheaper than the price in the Summit link you posted. His website is www.timssuspensiononline.com. Nothing against Summit (I order plenty of parts from them) but there are many supporting vendors that will be able to get you a better deal on those gauges.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
i order mine from classic instruments i had to get a signal generator for later model 700r they are very easy to deal with and can answer any question u may have
#7 | |
Which signal generator did it come with because I have a th350. Also, do you like the gauges and do they work well?
you can use sn16 screws into speedometer port on transmission. i really like the gauges they work very well i know the gauges are expensive but with the electic sender you can monitor the engine better, i got 160 mph and 8k tach
I ordered them from egauges.com
Rex |
motor exploder
I got the Velocity Series just like you posted above, but mine are black faced. If I remember correctly (it's been over a year since I got them) it only took a week or so for them to come in.
So other than having to buy another signal generator, all the wiring that was needed was provided and did not have to buy more wires?
