Old 06-06-2013, 10:51 PM   #1
70CHEVYBB
70CHEVYBB's Avatar
4 core rad conversion question
I have a 4 core radiator from a 72 and want to put it in my 70. I have a new radiator support and I saved the upper rad mounts. I bought new lower 4 core saddles and all new rubbers. I noticed the lower mounts do not fit in the radiator support. do I just bent the lip of the support down or cut it open to make it fit.
70CHEVYBB is offline   Reply With Quote
Old 06-06-2013, 10:55 PM   #2
70CHEVYBB
70CHEVYBB's Avatar
Re: 4 core rad conversion question
here is a pic of the problem
Old 06-07-2013, 12:12 AM   #3
HotRod C/10
HotRod C/10's Avatar
just bend it over enough with a pair of Dykes/Dikes.....walla!
where did you get those lowers at?
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 06-07-2013, 12:41 AM   #4
Ben.Riley
x2
I was JUST about to post this question.. I was going to cut, no particular reason, just thought bending wouldn't look as clean.
Ben.Riley is offline   Reply With Quote
Old 06-07-2013, 08:42 AM   #5
70CHEVYBB
70CHEVYBB's Avatar
lmc for the saddles and rubbers and they are very nice. I am just going to bend the lip with a adjustable wrench. I have already painted and cleared the support.
Old 06-07-2013, 10:04 AM   #6
Ben.Riley
could you possibly take a picture when done? I may just bend if it looks good.
Old 06-07-2013, 01:32 PM   #7
TheSeeker
Heat the area to be bent first, then bend it with a wrench like you plan. It will look much better than trying to crease it without heat, plus it will be easier!
TheSeeker is offline   Reply With Quote
