Old 06-26-2003, 08:53 PM   #1
hanssolo
hanssolo's Avatar
HEI guru questions
2 questions about internal coil HEIs:
1. Whats the difference between the red and black and the red and yellow wire coils?
2. What are the symptoms of coil saturation?
Thanx
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint
______________________________
hanssolo is offline   Reply With Quote
Old 06-26-2003, 09:44 PM   #2
sbc350gearhead
sbc350gearhead's Avatar
Symptoms of coil saturation? Do you heak heat soak? Coil saturation time, is the time required for a coil to reach peak energy on the secondary side of the coil.
sbc350gearhead is offline   Reply With Quote
Old 06-26-2003, 10:37 PM   #3
hanssolo
hanssolo's Avatar
red and white-sorry my mistake. OK, thanx. I've been informed to use GM modules because some of the cheapos in the auto parts stores don't have what the GM modules have....variable dwell. Its in the module itself. This is'nt a computer thing. This is supposed to keep the coil from "over-saturating" at low rpms. Its supposed to help the coil last longer and give sharper performance. I guess over-saturation is what I would like to know about. Could it just be over heating? Check this site out.
http://www.thirdgen.org/newdesign/tech/hei.shtml
ps- gearhead350- you were right about the PCV valve thing.
Old 06-26-2003, 10:59 PM   #4
sbc350gearhead
Over-Saturation probably refers to un-needed energy produced by the ignition circuit. This extra energy would shorten coil life due to the increase in heat. I honestly don't know of another downside, except that when amperage increases, resistance increases as well and therefore decreasing voltage. How much that would actually affect the very short path of the ignition circuit, I cannot say.
Old 06-27-2003, 07:26 AM   #5
JimKshortstep4x4
Smile
This was not one of your questions, but the pattern of a GM module is clearer on the distributor machine than after market
modules. After market modules will double flash when testing distributors. We only use GM modules in our HEI's because of the aftermarket modules inconsistant patterns of firing.
Jim
Old 06-27-2003, 09:46 AM   #6
hanssolo
hanssolo's Avatar
Jimk- thats good to know. But what do you mean by double-flash? Fire randomly a second time on the same cylinder? Thanx.
Old 06-27-2003, 11:05 AM   #7
JimKshortstep4x4
Smile
For the most part the aftermarket modules will fire in between
the normal flashes, so instead of (8) flashes per rev it will fire (16) per rev and they get worse as the rpm's increase. I am not absolutely sure of how it affects the running of the engine, but it can't be good.
Also, the clarity of the flash pattern is not good.
Jim
Old 06-27-2003, 06:26 PM   #8
sbc350gearhead
Are the aftermarket modules in question the aftermarket hipo stuff (accel, msd,etc), or the autozone stock replacement stuff?
Old 06-27-2003, 08:05 PM   #9
JimKshortstep4x4
Talking
They are replacement modules. I have never tested an accel or other hi performance modules so I don't know how they would fire on a distributor tester.
Good question!
Jim
Old 06-27-2003, 10:57 PM   #10
hanssolo
hanssolo's Avatar
Jim- thanx for all the info. Good to know.
