Old 06-26-2003, 09:29 PM   #1
1972ChevyGuy
1972ChevyGuy's Avatar
Feel My Pain
Was cruising down the road today and went to shift into 3rd. BLAM, the clutch goes to the floor with a nice little pop noise I get it back into 2nd without the clutch and nurse her home. (I killed my battery cranking it at the stoplights and signs ) Opened up the hood and the stinking ball joint thingy that goes into the block broke off at the block. Guess im gonna have to pull the motor to get an easy-out in there A few good things did come out of this tho....... I convinced the wife that the peice would cost alot, so she gave me money Bought a new steer wheel (Factory, truck has no power steering and had a small wheel on it when i bought it) Horn works for first time in 9 years, weeeeee, no more revvin it up when people wont get out of my way, the horn is going to get me hurt Somebody cry with me while I rip this motor out
1972ChevyGuy is offline   Reply With Quote
Old 06-26-2003, 09:33 PM   #2
toms68cst
toms68cst's Avatar
Are you sure you have to pull the motor? My pivot assembly is mounted to the block using two bolts.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 06-26-2003, 09:35 PM   #3
1972ChevyGuy
Yea, the bolt broke off just enough so I can't grab it with the pliers I ordered the whole new assembly from LMC, should be here tomorrow. MAYBE I can make some time to get it out
Old 06-26-2003, 10:00 PM   #4
krue
Designated A-hole!
krue's Avatar
I feel your pain! I am pulling the motor out of my stupid car because a spark plug hole stripped out! I wish it was as easy as pulling the motor out of my truck!
Good luck with yours!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 06-26-2003, 10:17 PM   #5
GMC71k20
i got mine out with a reverse drill bit, you dont have to pull the motor, if it still wont budge with the reverse drill bit start the motor and let it get warm, then try again and it might come right out
GMC71k20 is offline   Reply With Quote
Old 06-26-2003, 10:34 PM   #6
67cst
i love summertime
67cst's Avatar
yeah i agree with you guys, id try every last possible thing before id yank that old work horse out...ill shed a tear for ya though...
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 06-26-2003, 10:45 PM   #7
racedvl
racedvl's Avatar
What if you just pull the inner fender??
racedvl is offline   Reply With Quote
Old 06-27-2003, 12:30 AM   #8
6T9GMC
6T9GMC's Avatar
Unhappy
YEAH, MAN I'D TRY A COUPLE OF THOSE BEFORE I PULLED OUT THE MOTOR. IMO
HERE IS SOME MORE TEARS.....
6T9GMC is offline   Reply With Quote
Old 06-27-2003, 11:18 AM   #9
sniper2321
sniper2321's Avatar
here is a good tip if you have a propane torch you wont have to pull it. jack it up pull the wheel and inner fender. get an easyout or the reverse drill, a center punch, andsome penatrating oil bp blaster works real good. heat up the bolt and the block to the point were it gets just cherry red. know take the center punch and pop it 2 time with a hammer. it should cooler a littleto were the color is changing to black and spray a little!!!!!! bp on the bolt let it sit an cool. then use the bit or the easy out. i had to do this the 3 time in 2 months the ball stud just kept breaking so i went to a machine shop and had them make me a stainless one. hope this helps and good luck
sniper2321 is offline   Reply With Quote
Old 06-27-2003, 01:19 PM   #10
1972ChevyGuy
Thanks for the advice fellas, im not thinkin straight Ill try to take the fender well out. Thats a today job :/
