Old 06-07-2013, 04:46 PM   #1
Procurement_man
Procurement_man's Avatar
CPP 2/4 drop kit now nose high
The PO torched my springs so I got a deluxe 2/4 drop kit from CPP. Finished the install and the front is higher than the back by about 1 inch. Truck has a I 6 in it now... will a Small block bring it down to even? I plan on an engine swap soon. Can I combine the 2 inch drop springs with drop spindles? If I do that will the front then be too low and look funny? I like where the back is now.
"God will often give you more than you can handle so you can learn to depend on him rather than on yourself" ...Craig Groeschel
Procurement_man is offline   Reply With Quote
Old 06-07-2013, 05:00 PM   #2
tinydb84
tinydb84's Avatar
Re: CPP 2/4 drop kit now nose high
The small block might bring it down a hair. Drive it around for a bit and see if the springs settle before doing anything.
You can add drop spindles and be a 4/4 drop (which I would do)
David
Instagram: myfabguy
