Old 06-07-2013, 09:30 PM   #1
bonehead
bonehead's Avatar
Changing cab mounts with cab on
Has anyone changed the cab mounts without pulling the cab? Mine squeak a lot and they need replaced, but I don't want to pull the cab.
Can I just break them loose and lift the cab enough to sneak the new ones back in? Maybe do one side at a time? tips?
Some "how to" from some of you guys that already did this would be a help. I did a search and could not find this topic.
past trucks:
1980 C-10 Silverado SWB
1961 C-10 custom cab LWB
1966 C-10 custom cab LWB
bonehead is offline   Reply With Quote
Old 06-07-2013, 10:18 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Changing cab mounts with cab on
Yes, one side at a time. Make sure you shim the core support if needed for proper alignment of fenders to doors. What you change in height on the cab will effect front end sheet metal.
TBONE1964 is offline   Reply With Quote
Old 06-08-2013, 10:48 AM   #3
bonehead
bonehead's Avatar
So you don't think the new mounts will squish down to the height of the old ones, so I wouldn't have to mess with the core support?
Any further input?
past trucks:
Old 06-09-2013, 10:03 AM   #4
64c20crewcab
64c20crewcab's Avatar
It's only 2 bolts on core support.... And doubt the new body bushing will "squish"... To same height. If they do then you tightened them down too much....
..............................._________
......___________//___[[___{\ _____
...../__(_(O)_)___/____/____/_(O)_/
1964 C20 Long Stepside 3 Door Crew Cab
- Armbruster-Stageway Conversion
Y2K INDN Chief
"ONE OF A KIND, NOT ONE OF THE CROWD"
Aug 2010 - Front end frame cleanup & engine swap done!!!
June 2011 - Rear end bagged
Sept 2011 - Rebuild motor top end
Sept 2012 - Parked and slowly working on it.
Aug 2013 - Front end bagged - finally!
Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas...
Here is my build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=335427
64c20crewcab is offline   Reply With Quote
Old 06-09-2013, 04:18 PM   #5
TBONE1964
Cluster King
TBONE1964's Avatar
Just consider that fact that if there is any difference in height, the doors probably will not shut right and you will have panel alignment problems.
You may be able to chnge the cab mounts and be OK. You won't know until you do it, what the result is going to be.
I like to think of the cab and front sheet metal as one piece because what you do to one, will effect the other somehow.
Old 06-09-2013, 06:00 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
I did the same this on my 1960 GMC years ago. Pulled all the bolts and lifted one side at a time. It was easy as my front end sheet metal was off. It turned out to be a waste of effort when I discovered the mounts I was sold looked nothing like my originals. At the time no one produced mounts like mine, so I had to reinstall the bolts and leave them alone.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
