Old 06-07-2013, 09:39 PM   #1
UATahoe
Radiator installed, time to add coolant. What type of mix are you guys running?
In the process of installing my new motor and was able to get the radiator installed this afternoon. What kind of coolant are you guys running and what ratio of coolant and water? Stupid question I know but was just curious.
UATahoe is offline   Reply With Quote
Old 06-07-2013, 09:53 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Radiator installed, time to add coolant. What type of mix are you guys running?
Water... Lol. Till winter then I run 50/50 of whatever.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 06-07-2013, 10:11 PM   #3
UATahoe
Lol roger that.
Old 06-07-2013, 10:22 PM   #4
Rufton
Water is a good coolant but makes the cast iron flash rust quickly.
Aluminum may pit after anti corrosion components of coolant used up. If don't change on schedule then anti corrosion additive should be used.
Hard tap water can plug cores.
I use coolant+distilled water and heavy equipment filter w/ time release additive.
Rufton is offline   Reply With Quote
Old 06-07-2013, 10:31 PM   #5
UATahoe
Guess I will just go with a normal 50/50 mix. Any idea how much coolant it will take since its completely empty?
Old 06-07-2013, 11:38 PM   #6
king-918
king-918's Avatar
if the system is completely new why not use the new stuff
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 06-07-2013, 11:44 PM   #7
UATahoe
Just straight coolant?
Old 06-07-2013, 11:49 PM   #8
Rufton
Back in the day, prestone label included correct ratio for climate. Now 50/50 is common. Easy to remember and prestone gets to sell more coolant. Win win
Old 06-08-2013, 08:17 AM   #9
Sabaka454
Sabaka454's Avatar
NEVER! Do not run straight coolant. Unless it's premix run 50/50 mix with distilled water. Don't run tap water.
Sabaka454 is offline   Reply With Quote
Old 06-08-2013, 08:46 AM   #10
88Jimmy4x4
88Jimmy4x4's Avatar
Use distilled water not tap water and run that for awhile, then drain radiator and add coolant and distilled water since its a fresh rebuild.
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 06-08-2013, 08:58 AM   #11
andrewmp6
Evans sells a lifetime coolant but its not cheap.
andrewmp6 is offline   Reply With Quote
