Old 06-08-2013, 09:08 AM   #1
JMac11
JMac11's Avatar
Check Engine Light??
Searchy not revealing much..... On your swaps with modern engine, Where are you guys putting the Check Engine Light???
JMac11 is offline   Reply With Quote
Old 06-08-2013, 11:07 AM   #2
pumpkin
pumpkin's Avatar
Re: Check Engine Light??
I threatened one of my customers that I was going to put a check engine horn in his conversion. I opted for bright under dash lights instead.
pumpkin is offline   Reply With Quote
Old 06-08-2013, 12:11 PM   #3
Daner
Daner's Avatar
The worst would be the low air pressure buzzer out of a sterling semi truck. Ear splitting would be an accurate description.
Dane
67 Chevy Fleet 250/4 speed 1/2 ton
68 Chevy 250/4 speed 1/2 ton for parts
49 GMC Grain truck 235 1 1/2 ton
76 Chevy 350/4 speed 1/2 ton
Daner is offline   Reply With Quote
Old 06-08-2013, 04:37 PM   #4
RaceAGMC
RaceAGMC's Avatar
I put mine in the "Brake" light at the bottom of the fuel gauge.
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 06-08-2013, 04:55 PM   #5
Bigdav160
Bigdav160's Avatar
I didn't bother with a light.
If it quits running correctly I'll plug in the scanner.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 06-08-2013, 06:45 PM   #6
ole dollor
ole dollor's Avatar
check Engine light..? mine don't have one....its got me.
ole dollor is offline   Reply With Quote
Old 06-08-2013, 07:49 PM   #7
yuccales
yuccales's Avatar
I ran an old ABF Sterling for awhile, your description of the low air is spot on!
yuccales is offline   Reply With Quote
Old 06-08-2013, 10:35 PM   #8
jkeady
jkeady's Avatar
I'd run it to the Brake warning light as mentioned, or isolate it with a diode and run it to the high beam warning light. At least with that, if you're driving down the road and the high beam light should turn on out of nowhere, you know pretty much what's being communicated.
Josh
'70 Custom Camper / 20
jkeady is offline   Reply With Quote
Old 06-08-2013, 10:47 PM   #9
RaceAGMC
RaceAGMC's Avatar
I just didn't want to drill a whole in the cluster/bezel. So I used an existing space.
