Old 06-08-2013, 07:58 PM   #1
mr. g
Arrow performance small block & TH350 with aftermarket parts/accessories
...good and clean rebuilt transmission and chevy small block with heavy duty and performance parts
-solid street performance power train that was pulled and replaced with more power and performance and is no longer needed
-GOOD PRODUCT TAKEN CARE OF RESPONSIBLY...MANY ITEMS IN ORIGINAL PACKAGING-
ALL-IN-ONE SALE....NOT FOR SALE INDIVIDUALLY/PER PIECE
1973 K10 4-bolt engine (3970010/K0621TJZ), with fully-ported 882 heads has only~1000 miles since professionally rebuilt
1969 Caprice heavy-duty TH350 (Y9K 22D/CFD4) was pulled a little later and has only~1800 miles since professionally rebuilt
EVERYTHING CLEANED FOR REUSE; MORE THAN $2500 IN ACCESSORIES AND AFTERMARKET PARTS ALONE;
Edelbrock Elite cast aluminum air cleaner assembly
chrome air cleaner- drop base
TransDapt 1" air cleaner spacer
K&N air filter 15x4
K&N aerosol filter cleaner and oil
Edelbrock Performer RPM 850cfm quadrajet #1910, including gaskets, rebuild kit, race calibration kit, and tech.
Edelbrock 1" 4-hole q-jet spacer; treated hdf
Moroso 2" aluminum q-jet riser/adapter (for square bore manifold)
Edelbrock Performer RPM q-jet manifold
Edelbrock Elite cast aluminum valve covers
Edelbrock Elite cast aluminum breather; new filter media
Moroso steel-core valve cover gaskets
Accel HEI distributor
Accel header plugs
MSD 8.5mm wire set & extra boots & terminals
dist springs/weights kit
adj. vac advance modules
aftermarket distributor hold down/clamp
Moroso aluminum distributor housing/bushing with nylon shim washers
gear drive with offset bushings
1.5" accessory belt-drive kit
Lunati Voodoo camshaft #60103
Comp Magnum hardened pushrods
Comp Magnum roller rockers
Warner high-flow thermostat
ARP 12 pt. head bolts, 12 pt. damper bolt, heavy duty flexplate bolts
Professional Products sfi damper
billet timing pointer
stamped timing pointer
GM Performance head gaskets with stainless fire rings- installed, never run
GM Performance intake gaskets- new set
stainless-laminated composite exhaust gaskets- new set
Moroso oil pan & pick-up, reconditioned; new enamel
Melling oil pump 55
1.94/1.50 iron 882 heads, ported: intake 2.18x1.35, exhaust 1.48x1.38, 65cc combustion chambers, pinned studs
4 bolt block, 2 pc. rear main seal, balanced
hyper flat tops with valve reliefs
4.060" bores -honing patterns still present- good ring seating
9.16:1 compression ratio
B&M uni-matic shifter- no cable, no knob
Hughes Performance gm2500 torque converter, AND hd 1800 stall converter
chrome torque converter cover
sfi flexplate
Lockar kickdown cable- new
hard tube/dipstck, transmission- new
heavy duty TH350; 2.42/1.42/1:1 hardened sprag, 5-pack, yellow frictions, shift kit, adj. modulator...(i ran with B&M trickshift)
transmission oil cooler
Weiand team action water pump- surface rust removed; flushed/cleaned; new polyurethane, good impeller, no play
chevrolet stock starter
chevrolet early power steering pump
misc. fans
fan spacers and bolts
misc. bolts, gaskets, brackets, etc.
engine and trans were painted with high-solids polyurethanes- still looks good...
original product literature, instructions, and stickers; in a binder
boxes and bags for all items; can be shipped- i can build a bolt-in crate if needed, you pay cost on freight/delivery...
$3500 obo
mr. g is offline   Reply With Quote
