Old 06-08-2013, 08:25 PM   #1
66farmer
66farmer's Avatar
Wheel back spacing (HELP)
Time is running short for me. I need to order my wheels and I don't have the bed or the front fenders on as of yet. So I need some help from you guys.
My truck is a '66 short step-side 4.5" drop front and 6" in the rear. Stock rear axle width 5" on 5" bolt pattern, the front is 78 disc brake transplant. The rims I'm going to buy are Boss 338 18" front and rear. I want to fill the wheel well but I don't want to rub. Please let me know what has worked for you guys.
If you can only comment on the front please do.
Thanks for your help
66farmer is offline   Reply With Quote
Old 06-09-2013, 12:14 AM   #2
chevyrestoguy
chevyrestoguy's Avatar
Re: Wheel back spacing (HELP)
Go with the 18x9.5 in the rear. They have a 5.0" backspace, and they'll fit perfect. Go 18x8 in the front. They have a 4.5" backspace. They don't make anything narrower than an 8" in the 18 inch diameters.
If you order these wheels, ask the wheel guy if they'll clear the center hub of the front rotors. When these wheels first came out, it was a problem on the C-10s and guys had to either grind their rotors or run a spacer.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 06-09-2013, 08:53 AM   #3
66farmer
66farmer's Avatar
Thanks for the info, I will check on the rotor clearance
Old 06-09-2013, 12:39 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I jammed a 12"+ wide wheel and drag rad5ial in the back with an 8.5 bs
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
