Old 06-08-2013, 11:50 PM   #1
Benlugchev
Benlugchev's Avatar
I Keep popping 15 amp fuse
I Keep popping 15 amp fuse on my wire coming off back of alternator going to my "hot" power block
Does my wiring seem correct, it is based off research i did on this site and other forums.
Battery has 2 wires - 2ga to post of starter - neg to frame
Starter has 3 wires -2ga from + batt
- 10ga from big post to back of alternator
- purple wire from factory harness to little post
Alternator has 3 wire - 1 wire in plug that goes into computer
- 10ga coming from large post on starter
- 10ga with 15amp fuse going to constant "hot" power block
Harness only had 3 relays Fans, Fuel pump, IGN. (no other fuses)
- 2 wires coming off relays that called for "key hot"
- 5 wires coming out of harness and relays that called for "12V hot"
- 3 ground wires
- relay ground wire
Headlights/gauges are running off the stock harness/fuse box
Truck is running very rough and will barley idle. Seems to be misfiring
71' Chevy C10-Turbo 6.0L-80e-JFR218-738hp/700tq-10.1@133mph... 1.54 60' (3737lbs)
00' GMC-c2500-Turbo 6.0L-80e-JFR212-500hp/560tq -11.67@116mph (5182lbs)
Benlugchev is offline   Reply With Quote
Old 06-09-2013, 12:47 AM   #2
truckdude239
truckdude239's Avatar
Re: I Keep popping 15 amp fuse
15 amp doesnt sound high enough depending on whats running out of that hot box
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-09-2013, 07:24 AM   #3
Benlugchev
Benlugchev's Avatar
The hot box is running the relays for the fans, fuel pump and ignition. Along with power to the PCM and obd2 port.
Old 06-09-2013, 12:49 PM   #4
truckdude239
Your pulling to much juice though a 15 amp fuse
David fuller
2012 Subura outback
1999 honda accord
Old 06-09-2013, 03:06 PM   #5
mooseknuckles
mooseknuckles's Avatar
x2...overloaded!
mooseknuckles is offline   Reply With Quote
Old 06-09-2013, 05:46 PM   #6
truckdude239
it probley should be around a 30-40 amp fuse i'd say
David fuller
2012 Subura outback
1999 honda accord
Old 06-09-2013, 08:30 PM   #7
Benlugchev
Benlugchev's Avatar
Awesome thanks. I'll through in a 30 amp and she what happens.
electrical, electrical short
