06-27-2003, 12:41 AM | #1 |
crossover steering
well guys I've decided to adapt the crossover steering to my 69 4x4 but I have the old style front axle ( ball & trunnion ? ) Does anyone make a steering arm for these ? I think this one would attach to the top RH knuckle where the pivot bearing is . Has anyone done this before ? I can't afford the newer style axle for a while so I have to work with what I've got ! Thanx.
06-27-2003, 04:00 AM | #2 |
I need another Barley Pop
Charlieo, I don't have my old closed knuckle axle anymore so I couldn't tell you for sure whether or not it would work. I would guess that if the passenger knuckle (be it open or closed) has a flat pad for mounting the arm to accept a tie-rod end, you should be able to make it work. If not, some machine work might be required and that may cost you more than swapping in a later model disc brake open knuckle axle.
67 Short Fleet 4x4 04 Honda CRF450R 89 Toyota 4-Runner 34 Ford 2 door sedan - Long term project ---------------------------------------------- There is a very fine line between "hobby" and "mental illness" |
