Old 06-09-2013, 01:55 AM   #1
76chevycummins
AAM 11.50 rear disk brake question
Hi I've been following this site for awhile and finally decided to join up.
I have a question I'm hoping somebody can help me with. I'm putting together a 76 chevy k 30 crew cab with a 12 valve cummins. I'm to the point where i'm ready to put in a rear end (truck was a dually when i got it). I picked up an AAM 11.50 axle for it awhile back but I'm unsure what I would need to do to make the disk brakes work with the existing brake system. I have searched around and there seems to be a lot of different opinions. New master cylinder, modify the proportion valve, or put in a pressure limiting valve. The thing is I need the brakes to work properly because the truck will be used to pull a lot of weight from time to time. I'm also considering just going with a 14 bolt with the drum brakes on it. this gives me the assurance that the brake system will work as GM designed it to. I've never had a problem with the rear drums on any of my other trucks stopping me so this idea appeals to me a lot, but it would require setting the 14 bolt up with 3.73 gears. Anyway I'd appreciate any help or opinions. ps sorry if this has been covered before.
76chevycummins is offline   Reply With Quote
Old 06-09-2013, 09:55 AM   #2
hatzie
Moderator
hatzie's Avatar
Re: AAM 11.50 rear disk brake question
The disc drum brakes are biased differently from disc disc.
Can you get the proportioning valve from your axle donor?
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-09-2013, 02:39 PM   #3
76chevycummins
I bought the axle off ksl a few years ago and i'm sure that truck is long gone. The axle came off a 2003 duramax truck though so if I went to a salvage yard I could probably find a proportioning valve off a wrecked truck. Would I need the master cylinder from the newer truck to or will mine work.
Old 06-09-2013, 08:37 PM   #4
clinebarger
Late 3 channel ABS trucks have the Proportioning built in to the ABS hydraulic control unit....No use to you.
Late master cylinders use metric bubble flares.
A C3 Corvette master cylinder & a Wilwood adjustable proportioning valve would work on you truck in conjunction with AAM axle.
clinebarger is offline   Reply With Quote
