![]() Join Date: Jul 2001
canceling cam for a TILT column needed
I need a canceling cam and related parts for a tilt column. I am replacing an aftermarket wheel with a stock one, so I need any related items.
Are these available new? thank you, Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
![]() Join Date: Jul 2012
Re: canceling cam for a TILT column needed
My local NAPA had a canceling cam in stock but had to order the turn signal harness. The point being that the parts are available. Hope this helps...
Truckin' Krazy
![]() Join Date: May 2000
I have new reproduction cancel cams for $12
Thanks, Tom
Dealer for: American Auto Wire Precision weatherstripping Dakota Digital Trim parts Carpets Truck World seat covers & Many others Chevy Parts locator in Mesa AZ! |
Custom Sport W/T
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Ray what related parts do you need? I have an excellent canceling cam and the spring that holds it down as well as all of the parts under the horn cap....Roger in Annapolis
#5 | |
I have the parts under the horn cap. I need everything else related to the canceling cam. thanks, Ray
Tom,
I am going to see if I can get all the items at once. thanks, Ray
Custom Sport W/T
Ray if your turn signal switch is complete and working you will only need the cam and spring. $15
Roger, I think eveything else good. I am just replacing an aftermarket wood wheel and going back to an original.
thanks, Ray
![]() Join Date: Jun 2011
Are the tilt and non tilt cams differant ?
