Old 06-27-2003, 12:50 AM   #1
breeh
Recovering 67-72 Addict
breeh's Avatar
Steering Brace
Anyone done one in 67-72? I was watching my frame today while someone turned the wheel and there was whole lot of flexin' goin' on. I would like to firm things up before the dreaded frame crack. I see there are kits for 73-87 but I cannot find anything for 67-72.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 06-27-2003, 01:41 AM   #2
darksaga
darksaga's Avatar
I have the same problem
1968 gmc 3/4 4x4 longbed. built 469 700r4 (needs a th400 REAL SOON!), 14bolt ff rear 73 3/4 dana 44
1970 chevelle all wheel disc, tubular rear control arms tall spindle swap up front matching #'s 350 work in Progress
darksaga is offline   Reply With Quote
Old 06-27-2003, 05:19 AM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I heard that the 73 and up would work but you have to modify it first.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 06-27-2003, 07:58 AM   #4
JimKshortstep4x4
Smile
Some of the 71-72 Blazers and I believe some of the 71-72 trucks were equipped with reenforcing steel sections where the steering box mounts up. You might consider looking for one of those. The reenforcements are welded and riveted in place so they are are a bear to remove if you find an old frame with one on it. Try posting on the parts section with a wtb.
Jim
Old 06-27-2003, 10:32 AM   #5
6869704X4
darksaga, Got some pics of the brace. At work now wil put them up when I get home.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 06-27-2003, 11:04 AM   #6
darksaga
darksaga's Avatar
thanks
Old 06-27-2003, 11:44 AM   #7
Yukon Jack
Post Whore
Yukon Jack's Avatar
I'm not sure if Offroad Design's brace will work on our years. You might check over at ColoradoK5 in the 69-72 section as I bet someone there will know on the ORD brace.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 06-27-2003, 12:52 PM   #8
breeh
breeh's Avatar
JimKshortstep4x4, I did purchase one of the reinforcement plates that you are talking about from a boardmember. However, I am not sure that that will take care of the flexing issue. I think some sort of gusseting is in order.
6869704X4, I am looking forward to seeing those pics as well.
Yukon Jack, I was thinking about checking the CK5 site as well. Have you seen anything similiar posted there before?
Old 06-27-2003, 01:11 PM   #9
darksaga
darksaga's Avatar
this is the post I had about almost the same problem
http://64.246.42.114/vboard/showthre...threadid=55994
Old 06-27-2003, 06:49 PM   #10
6869704X4
breeh, pics are on the link darksaga put up.
Old 06-27-2003, 07:09 PM   #11
breeh
breeh's Avatar
Thanks for the link. I am familiar with the reinforcement plate. I am thinking more along the lines of gusseting the area though. Jerry Moss, if you are following this thread, what are your feelings on gusseting somehow? In the other thread it sounded like you felt that this would just cause cracking in other areas (fore and aft of the gusset).
Old 06-28-2003, 11:10 AM   #12
jerry moss
Born Psycho
jerry moss's Avatar
the factory steering box support actually ties into the front crossmember under the radiator so it spreads the load to both framerails.
i'm not sure extra gussets would do any more than the factory brace does. the frame is made to flex quite a bit and if you stiffen it too much in any one area, you remove the ability of the frame to flex in that spot.
there's a welding shop here in town that does frame shortening with no plates, they cut a "Z" section out of the frame and weld it back together. their own service truck is a late model F-350, diesel, 4x4 that they cut down the day they took delivery of it from the dealership. it's used everyday out in some rough terrain, loaded with supplies and towing a big welding trailer. these same guys build jeeps for the rubicon and other 4x4 events where twisting the frame is common so they know their business. years ago when i was into jeeps and didn't know any better, i'd plate the cracked areas and sure as heck it would break on one side or the other of the plate. the last jeep i built, i boxed both frame rails from front to back. it never broke while i had it but it didn't flex at all, had to use some modified springs to get some twist.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 06-28-2003, 01:25 PM   #13
6869704X4
Here's a story that relates.
In the early 80s we started finding cracks in the outer wings of our C-130s. The solution was new outer wings with additional stiffeners to make them stronger. Guess what? Several years later we started finding cracks in the center wings.
So, just like truck frames, make one area stronger and you find a weaker one.
Old 06-29-2003, 12:34 PM   #14
breeh
breeh's Avatar
Thanks Jerry, that was very helpful. I guess I will start taking that thing apart so that I can get that factory reinforcement plate installed. Then I will just watch and see what happens.
