Old 06-09-2013, 03:12 PM   #1
mooseknuckles
mooseknuckles's Avatar
E-fan relay ?
I get a clicking noise form the second elec. fan relay when it want s to come on. I've tried switching relays and it still does it.....the first fan comes on when its supposed to and works perfectly, but the second fan relay just clicks....
mooseknuckles is offline   Reply With Quote
Old 06-09-2013, 07:23 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: E-fan relay ?
fan motor seized up and drawing too much current, popping the relay?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-09-2013, 07:40 PM   #3
Crash_OK
Crash_OK's Avatar
Re: E-fan relay ?
Is this a new install or did the second fan work in the past?
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 06-09-2013, 08:46 PM   #4
mooseknuckles
Re: E-fan relay ?
this is a brand new rad and e-fans.....the second fan works, but it never ever has come on when the pcm calls for it to come on. just the clicking in the relay.....I just put it off to being something wrong in the tune...?
Old 06-09-2013, 08:50 PM   #5
Crash_OK
Crash_OK's Avatar
Re: E-fan relay ?
How are the relays wired.. Could it be a problem with the wiring? The factory wiring normally (the ones I know of) have 3 relays and run both fans at half speed or both at full speed. I am not sure what you have for your setup.
Mark
Crash's 69 4x4 SWB
Old 06-09-2013, 09:37 PM   #6
mooseknuckles
Re: E-fan relay ?
it's a PSI harness, and I tried switching the wiring and it still didn't matter, whatever fan was #2 the relay still clicked....
Old 06-10-2013, 01:22 PM   #7
solidaxel
solidaxel's Avatar
Re: E-fan relay ?
Does the second fan work when you put 12VDC to the hot side of the fan?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-13-2013, 03:14 PM   #8
softballnrd27
Always a work in progress
softballnrd27's Avatar
Re: E-fan relay ?
I have the exact same issue. It is only on the 2nd fan relay. I can take the signal wire and swap them on the relays and the fan works just fine. I just hooked up a switch to control the 2nd fan until I can find out why it does that.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 06-15-2013, 05:52 PM   #9
mooseknuckles
Re: E-fan relay ?
both relays are wired the same, both fans work when hooked to 12v direct...so now I just wired both fans from the #1 signal wire, so when it comes on, both fans work...
Old 06-16-2013, 09:15 AM   #10
Hart_Rod
Hart_Rod's Avatar
Re: E-fan relay ?
Disconnect the computer signal to the #2 fan and trigger (ground) it manually. If that works then there is a problem with the computer or the tune. If it doesn't work, something is wrong with the way the #2 relay is wired.
Hart_Rod is offline   Reply With Quote
Old 06-17-2013, 10:05 AM   #11
mrhurt73
Re: E-fan relay ?
ok i had the very same problem, i had the a/c pressure set to zero in the tune. i dont have the a/c run to the PCM, but its still looks for it.
i set the a/c pressure way up and it stop doing it and fan 2 operates properly now.
i had to figure it out by going on HP scanner and manually turning on fan 2 and it work fine, so i knew it was something in the tune.
hope this helps.
My Projects-
http://67-72chevytrucks.com/vboard/s...d.php?t=557301
Quest for Hot Rod Power Tour 2013.
http://67-72chevytrucks.com/vboard/s...d.php?t=543735
my 85 GMC 2wd to 4wd conversion for the wife.
mrhurt73 is offline   Reply With Quote
Old 06-17-2013, 02:33 PM   #12
mrhurt73
Re: E-fan relay ?
see thread below where is posted mine.
http://67-72chevytrucks.com/vboard/s...d.php?t=574834
My Projects-
Old 06-30-2013, 06:44 PM   #13
mooseknuckles
Re: E-fan relay ?
thanks I'll give that a try.....
Old 07-06-2013, 05:00 PM   #14
mooseknuckles
Re: E-fan relay ?
tried that out today....#2 fan comes on when ya ground the relay, so now what?....lol
Old 07-08-2013, 12:29 PM   #15
mrhurt73
Re: E-fan relay ?
did you check the A/C settings in the PCM?
thats what was wrong with mine.
My Projects-
Old 07-08-2013, 06:21 PM   #16
mooseknuckles
Re: E-fan relay ?
umm...yeah. I got no way of doin that...
Old 07-09-2013, 07:08 AM   #17
mrhurt73
Re: E-fan relay ?
remind me how did you get your anti theft turned off in the beginning?
you may have to get a tuner to look at it for you.
everything you described, sounds just like the problem i had.
i could be wrong, but you have already tried all the simple stuff.
My Projects-
Old 07-09-2013, 06:04 PM   #18
mooseknuckles
Re: E-fan relay ?
I bought the pcm from PSI already to go ...or so I thought.
Old 07-10-2013, 07:01 AM   #19
mrhurt73
Re: E-fan relay ?
i would call and confirm yours was set up to have 2 electric fans run off the PCM, its not the default choice, so someone would have had to set it.
worst case, is taking the PCM out and mailing back to be changed. i know not entertaining idea, but better than listening to a relay click in a hot truck
My Projects-
Old 07-10-2013, 05:00 PM   #20
mooseknuckles
Re: E-fan relay ?
yeah....it's supposed to be set up for two fans, one at 182* the sec at 192*, but there were a few other things that were supposed to be done as well....in the meantime the one relay is running both fans....
