Old 06-09-2013, 03:41 PM   #1
JOJABOY
Windshield Washers
Maybe I'm working too hard lately....my brain keeps giving me the old buffering circle. I actually have a minute or two to do something so I figured I would take a look at my washers.
I have a late model washer tank with a built in pump. that part works great. I have new washer fluid lines that TEE into two and go to each nozzle. However the passenger side doesn't seem to want to squirt.
I've tried blowing air through the nozzle in reverse. I've tried the safety pin cleaning method. The only thing I haven't done is disconnect the lines to check for pressure beyond the TEE.
Any thoughts before I pull my cowl apart? Anyone had any issues with single line to TEE into two lines for the sprayers? Anyone have a better sprayer on their truck vice the original 1969 type?
JOJABOY is offline   Reply With Quote
Old 06-09-2013, 03:58 PM   #2
vidman
vidman's Avatar
Re: Windshield Washers
Do you have the tee exactly in the middle of the 2 squirters so you would get even pressure???
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 06-09-2013, 04:00 PM   #3
JOJABOY
i do
