06-09-2013, 04:23 PM | #1 |
Moderator
Cirtique my bed flange repair idea please!
Making progress on my bed rebuild for my long fleet. The flanges on the inner bedsides that sit on top of the wood are rough (think angle strips on Stepsides). So, I have come up with the plan to fix. A simple angle piece, 1"x"1" with the appropriate holes. Probably bolted to the bed sides.
Have a look at my diagram that I came up with, and let me know if there is anything that should be changed/deleted/added. I would like to take this to the metal store tomorrow. |
06-09-2013, 04:39 PM | #2 |
1961 crewcab
Re: Cirtique my bed flange repair idea please!
seems good, is 1 inch up the side enough to cover the rough stuff?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
06-09-2013, 04:53 PM | #3 |
Moderator
Yes, no rust on the vertical part at all, just the horizontal part that touched the wet wood. Not sure if I should put the new pieces in front or behind the metal.
Also, 16ga or 18ga? |
06-09-2013, 04:57 PM | #4 |
I would just note the left and right sides. If you make 2 identical pieces you will either have 2 lefts or 2 rights,of each part in referrence to the bolts spacing.
I am sure you already allowed for that, just ementioning because it wasn't noted on drawing. Very good planning/detail, tho! |
06-09-2013, 05:29 PM | #5 |
Moderator
06-10-2013, 01:12 AM | #6 |
60-66 Nut
I did something similar to this on a lower bed flange a couple years ago. I drew up what I wanted and had the pieces laser cut out of 18 ga. including the square holes. Then I formed them to a 90* and welded them into the bed.
