Old 06-09-2013, 07:19 PM   #1
spacetransient
1986 1/2 ton Rear Brake- 2-3/4" vs 2" Shoes
Does anyone know what is involved in swapping out drums/shoes from the 11" x 2" drums/shoes to the 11-5/32 drum & 2-3/4" shoes? Inside specs are almost identical. Wheels are the same 5x5.
Drums are deeper of course but otherwise, what would be the problem with a swap? I would really like to use the larger pads if I could!
Thanks for any responses
spacetransient is offline   Reply With Quote
Old 06-09-2013, 07:32 PM   #2
SCOTI
SCOTI's Avatar
Re: 1986 1/2 ton Rear Brake- 2-3/4" vs 2" Shoes
The backing plates, drums, & shoes are different between the two versions. All other parts/hardware swap over.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-09-2013, 07:39 PM   #3
spacetransient
So is the bolt pattern for the backing plate the same? If so this would seem to be a simple swap- the backing plates are only like $20
Drums are a wear item anyway and mine are due for a turning/brake job.
Any reason not to spend the extra $20 x 2 plates; and get new drums?
(any downside to this other than some initial cost?)
Thanks!
Old 06-09-2013, 07:43 PM   #4
SCOTI
SCOTI's Avatar
Yes, the bolt pattern for the plates is the same. Where did you find the 'correct' backing plates for $20?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-09-2013, 08:19 PM   #5
spacetransient
$20 each- Junk yard of course
Still- anything I can do to extend brake life is worth it to me.
Many thanks!!
Old 06-09-2013, 08:24 PM   #6
SCOTI
SCOTI's Avatar
Many thanks!!
Ok... for used parts that's about right. I've done this swap on 3 of my trucks now. Increases friction contact area by 35%.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
