Old 06-10-2013, 12:24 PM   #1
eljefe73
TH400 Torque converter going bad?
I've got a 402 with a TH400, it's dialed in with a Holley and HEI. Recently under load and low RPM, like pulling a trailer from stop or uphill, it bogs down. Not even revs up, or spins tires. other than a slightly hard shift (which i don't think is too severe) there are no other sympthoms. at a running stop, it'll still spin the tires down the block, but from a dead stop or load it'll bog down or lag. Fluid levels are good and not burnt. any thoughts?
eljefe73 is offline   Reply With Quote
Old 06-10-2013, 07:11 PM   #2
oklalawnboy
oklalawnboy's Avatar
Re: TH400 Torque converter going bad?
Is it downshifting to first. I would think if Torque convertor was going it would rev with not much movement. It sounds like it is trying to take off in second.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
