Old 06-10-2013, 01:49 PM   #1
agnes the dog
agnes the dog's Avatar
Door handle problem
My interior door handle keeps falling off. I have the lever type that rotates on the splined shaft, held on by an allen head set screw. I have tightened the set screw over and over and it only lasts maybe a month. Then it's back to falling off when I shut the door. It appears that the splines are intact, but maybe not enough to hold the handle on?? Anyone have a fix for this? I'm getting too used to opening it from the outside.
I am also considering a way to turn it into more of a knob than a handle. I'm interested to see if anyone has any brainstorms for this.... Maybe threading the shaft and using a flat style shift knob??? Just thinking out loud...
agnes the dog is offline   Reply With Quote
Old 06-10-2013, 02:11 PM   #2
HiRMKin
HiRMKin's Avatar
Re: Door handle problem
Just a thought but would there be a hairline crack in the handle around the threads for the allen set screw. If there is the set screw will never stay tight.
HiRMKin is offline   Reply With Quote
Old 06-10-2013, 02:33 PM   #3
solidaxel
solidaxel's Avatar
I drill a pilot hole in the shaft at the location of the set screw and put some Teflon tape on the set screw.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-11-2013, 09:44 AM   #4
Katrina/10
Katrina/10's Avatar
If you look inside the hole in the handle, you will see a set of larger threads above the set screw. This is for a lock bolt that screws down on top of the set screw. Basically a set screw on a set screw. If you put the second one in, the first one won't loosen up.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 06-11-2013, 09:57 AM   #5
mknittle
mknittle's Avatar
use blue locktite{serviceable} on the screw if everything else is good. Teflon tape would work but putting it on would be a kin to brain surgery on an insect.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 06-11-2013, 11:56 AM   #6
NEWFISHER
NEWFISHER's Avatar
Do you have arm rests? My handle was always falling off before I installed arm rests. I would use the handle to pull the door closed, only making the issue worse. I tried all of the tricks, marking the screw with grease and drilling a pilot hole in the regulator shaft was the final answer and it seemed to work the best. I installed arm rests and not only are they comfortable, but everyone uses them to pull the doors closed instead of the handles and I haven't had a problem since.
NEWFISHER is offline   Reply With Quote
Old 06-11-2013, 12:34 PM   #7
agnes the dog
Lots of good ideas! I might incorporate all of them. No cracks in the handle and no arm rests. I only use the door edge to pull it shut since I have to slam it. :-) thanks for the suggestions!
Old 06-11-2013, 05:23 PM   #8
Dan in Pasadena
Dan in Pasadena's Avatar
Originally Posted by mknittle View Post
...Teflon tape would work but putting it on would be a kin to brain surgery on an insect.
You guys make me laugh out loud. Then my co-workers think I'm (more) nuts.
Dan in Pasadena is offline   Reply With Quote
Old 06-11-2013, 09:46 PM   #9
OrrieG
OrrieG's Avatar
Maybe someone along the line tapped the second set?? Mine only has one set of threads and the screw is flush with the knob housing when tightened.
OrrieG is offline   Reply With Quote
