Old 06-10-2013, 06:13 PM   #1
ezstriper
ezstriper's Avatar
Parking brake cable routing
trying to hook up my emergency brake cable on my 72 w/B/B, the ft and both rear cables were there..ordered what I thought I needed from LMC truck...no tech help there....have the Dia from there site but can't figure out where the long rod attaches on the frame and the small wire holders...and the cable seems way to long...it's the right # for a B/B w/t400 S/B any help greatly appreciated ! Rob
ezstriper is offline   Reply With Quote
Old 06-10-2013, 06:45 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Parking brake cable routing
Scroll down on this site for and there's a pic that may help.
http://www.inlinetube.com/PDF%20cata...M%20Cables.pdf
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 06-10-2013, 06:47 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Forgot to ask: What does the engine size and transmission type have to do with the parking brake cables?
Reason I ask is because owners have done a lot of swapping around and I never knew there was a difference.
06 Trailblazer
Old 06-10-2013, 07:14 PM   #4
ezstriper
ezstriper's Avatar
not sure but they list different ones w/w/o B/B and turbo 400 as well...
Old 06-11-2013, 12:45 AM   #5
FirstOwner69
FirstOwner69's Avatar
These pictures may help. They're of my 69 3/4 ton with a 350 and TH400. The front cable attaches to the intermediate cable where the zip tie is on the left side. I understand that some with the TH400 had 2 loops under the trans tail shaft. Mine has always had just the one in the picture.
FirstOwner69 is offline   Reply With Quote
Old 06-11-2013, 07:38 AM   #6
ezstriper
ezstriper's Avatar
Thanks guys !! did figure out that LMC sent me the wrong int cable...sent for a long bed...they are not very helpful with any questions so you better know exactly what you need when using them....
