06-10-2013, 07:36 PM | #1 |
adding 4'' lift. what needs to be changed
lookin to put in a 4'' lift kit in my '69 gmc 4x4 3/4ton, dana 44 front, and dana 60 rear, front has closed knuckle. is this just a drop in deal or is there more involved? at moment rear has 7 or 8 leafs plus helper springs which will come out, front has 3 leafs. will there be any driveshaft issues? and who sells a good setup? thanx, paul
06-12-2013, 07:30 AM | #2 | |
67-72 parts collector,…
Re: adding 4'' lift. what needs to be changed
Anyone?
06-12-2013, 05:55 PM | #3 |
I have the same exact set up and I am looking to put 35 on it so I would be interested in hearing replys too.
06-12-2013, 06:07 PM | #4 |
as i remember for 80-87 chevys once you get higher than 4'' lift the steering arm gets involved, im just wondering if one is available for 67-72 trucks?
06-12-2013, 06:49 PM | #5 |
I don't plan on any more then 4". I should not have to change anything other then possibly the closed knuckle to an open plus disk brakes.
06-12-2013, 08:21 PM | #6 | |
From the Tuff Country Instructions:
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
06-12-2013, 08:27 PM | #7 |
thanx 4 the info Bigdav160 !
