Old 06-10-2013, 09:23 PM   #1
Claytona08
Claytona08's Avatar
AC questions
I have a 84 C10 and the air hadn't worked since I bought the truck several months back. I bought a kit to convert it to the 134 coolant. I cranked the truck and turned the air on max. Nothing happened. When I turned the air on high it would blow hard but no cool air. I'm confused on why nothing happens when I turn the knob from off to max. Even when the knob is off and I switch it to high it blows air out.
http://67-72chevytrucks.com/vboard/s...d.php?t=580955
http://youtu.be/JYoQJYTXKqI
1984 Chevrolet Scottsdale C10 "Project Platinum C10"
1971 Chevrolet Chevelle "Project Car"
Claytona08 is offline   Reply With Quote
Old 06-10-2013, 11:10 PM   #2
pontgta
pontgta's Avatar
Re: AC questions
Did you put the Freon in...LOL..... OK, so what are the pressures? no gauges? Take the low side pressure switch and bypass it and the compressor should cut on, if not you have to see why. of the compressor cuts on then you will probably be low on Freon.
pontgta is offline   Reply With Quote
Old 06-11-2013, 08:07 AM   #3
Claytona08
Claytona08's Avatar
Re: AC questions
The kit I bought has some gauges with it and showed after I put a can of freon in it to be approx. 50lb. What do you mean by bypass the low pressure switch? Thanks for your help.
Old 06-11-2013, 08:32 AM   #4
86c20
86c20's Avatar
Re: AC questions
50 may not be enough renember low presser no pump. i think these trucks take aroubd 2.5 of freeon.
also 134a will be 70psi at 70 degress. try adding one more can and i bet it will come on
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 06-11-2013, 08:37 AM   #5
Claytona08
Claytona08's Avatar
Re: AC questions
Oh ok, The instructions told me to put 50-55psi @ 90 degrees. I wasn't sure on what to do to be honest. I'll give it a try this evening.
Old 06-11-2013, 11:40 AM   #6
pontgta
pontgta's Avatar
Re: AC questions
That is correct 50-55, but that means when the compressor is on the pressure should be about 50-55.
When i said bypass the switch....I meant taking a wire and disocnnectinng the switch form the accumulator and bypassing the plug. should have 12v at one of the wires on the connector. take volt meter and one lead to ground and the other to one of the pin on the connector and should read about 12v...
Old 06-11-2013, 11:56 AM   #7
wraprail
wraprail's Avatar
Re: AC questions
Do you even know if the compressor is coming on?
The center should "click" on and spin with the pulley/belt
No compressor spin=no workie
wraprail is offline   Reply With Quote
Old 06-14-2013, 08:57 AM   #8
Claytona08
Claytona08's Avatar
Re: AC questions
So I got the 3 cans of freon in the AC and the compressor cuts on for a second and then cuts off. It keeps doing that over and over. The clutch on the front of the compressor kicks on and off.
Old 06-14-2013, 09:43 PM   #9
86c20
86c20's Avatar
Re: AC questions
do you know what your pressures are? got to no so you know how much more to go
Old 06-14-2013, 11:09 PM   #10
JellyBeanDriver
Re: AC questions
Agreed. The cycling switch turns off the compressor when the low side pressure is too low. It can be low because it's too cold on the low side, or the pressure is too low due to insufficient fill.
86' C30 Dually Crew Cab Ranch truck, carb'd 454, TH400, towing a slant load 4 horse trailer.
JellyBeanDriver is offline   Reply With Quote
