Power Steering lines & one other ?
Hey guys, I just mounted my ps pump and now I need to find lines that will fit in my setup. I have the gear box mounted with lines attached but they were cut, can anyone guide me to a year of truck I could take from to bold in or maybe a company that sells hoses I could use??
![]() don't mind the beat up pump.. I just need to get her running.. then upgrade. ![]() ![]() last question.. what is this bracket and does anyone of a clear pic of how its installed? ![]() goes here I assume?? ![]() |
![]() Join Date: Apr 2011
Re: Power Steering lines & one other ?
I replaced my pressure hose with NAPA Part # NPS 71634 and it fit fine.
For the return, I used bulk hose from the parts store between the fittings on the pump and the box. Hope this helps. |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
The bracket goes in behind the grille under the hood latch and sits vertically for support.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
MidLifer Thank you, I'll get that part and see what happens. Any tips help
![]() VetteVet; I thought so.. I'll have to look at it again. Am I holding it the right way? or flip it? |
Msgt USAF Ret
That's the correct way, Here's a picture of mine.
Thanks man! That's great. I appreciate the help guys!
Posted via Mobile Device |
