Old 06-10-2013, 11:58 PM   #1
weever82
weever82's Avatar
Headers for a lowered BBC that won't rub....
I have ceramic coated Long tube Hooker headers on my 454 in my 69 SWB and my right header is hitting on my passenger side control arm...
Wanting to stay with long tubes if I can but looking for headers that won't rub. I have 2.5" drop spindles and a 2" drop spring.
Maybe some Doug Thorleys looked nice but don't know anyone using them. Don't want to order new headers and they rub just as bad.
Thanks for reading and can get some pics up tomorrow if needed.
Weev-
Life's tough...... It's even tougher when your stupid - John Wayne
weever82 is offline   Reply With Quote
Old 06-11-2013, 12:43 AM   #2
BossHogg69
motor exploder
BossHogg69's Avatar
Re: Headers for a lowered BBC that won't rub....
You may look into getting some Chevelle headers... I started out with Hedman Elites for 67-72 Chevy trucks, but they ended up hanging down too low (4.5" drop), so I ended up trying out a set of Hedman Elites for a Chevelle. Below, the first pic is with the truck header on the driver side, the Chevelle header on the pass side. Neither set ever came close to hitting the A-arm, I just changed because I didn't want to bang the collector on the ground. I'm using CPP arms, so I can't speak for the fitment with factory arms, though I don't see it being a problem. These are mock-up pics btw, but the truck is fully assembled.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 06-11-2013, 06:31 PM   #3
396C20
396C20's Avatar
Thanks for those pics BossHogg. Very good comparison and easily noticeable height difference.
69 Chev C20 396 T400 Dana 60 3.54 A/C Daily Driver - Stolen
67 Chevy C20 CST
396C20 is offline   Reply With Quote
Old 06-11-2013, 07:00 PM   #4
seafoam68
seafoam68's Avatar
Boss Hogg, I also have a set of the Chevelle headers but am stalled on project right now. I do have them in the truck on a mock up engine and I notice the driver side has a very sharp turn down at the collector. I am wandering how you made this work? Thanks
seafoam68 is offline   Reply With Quote
Old 06-11-2013, 07:14 PM   #5
weever82
weever82's Avatar
How part # did u go with? When I look on the website there is 3 diff options. Is your engine a 454 also?
Thanks again for the info.
Weev-
Old 06-12-2013, 12:08 AM   #6
BossHogg69
motor exploder
BossHogg69's Avatar
Are they full length headers or shorty/mid length? Mine don't have any 'turn down' the collector exits parallel with the framerail. I'd have to see a pic of what you mean. I will say on the driver's side if you're using a BB with '72 only mounts/clamshells, the part of the mount that bolts directly to the engine will need a little notch cut out to clear the tubes because they tuck close to the block. That was the only issue I saw on the driver's side.
Part number for the Hedman Elite Chevelle headers is 68198. My engine is a BB chevy. I will say I don't have a factory trans x-member in my truck, I'm using a GMC Pauls trans x-member, so I don't know how these will fit with factory stuff. The truck I'm building is a hodgepodge of mismatched junk, so don't take my word for any fitment quality other than what you can see in the pics.
Adam
Old 06-12-2013, 02:06 AM   #7
68 TT
Still plays with trucks
68 TT's Avatar
Originally Posted by BossHogg69 View Post
...Part number for the Hedman Elite Chevelle headers is 68198. My engine is a BB chevy. I will say I don't have a factory trans x-member in my truck, I'm using a GMC Pauls trans x-member, so I don't know how these will fit with factory stuff. The truck I'm building is a hodgepodge of mismatched junk, so don't take my word for any fitment quality other than what you can see in the pics.
I had the Hooker standard competition series big block Chevelle headers on my stepside. They fit great with nice ground clearance. My front crossmember was lower than the collector. Only issue is the collectors exit right into the side of a stock trans crossmember. Need a tubular crossmember to use them.
They are not designed for clam shell motor mounts so if you run them you will need to trim a small corner off the bucket to clear one of the tubes on the drivers side. Easy fix.
What's funny is that the big block first gen Camaro headers don't even come close to fitting.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 06-13-2013, 08:50 PM   #8
seafoam68
seafoam68's Avatar
BossHogg, mine are Patriot Clippster mid length headers for a Chevelle. There is excellent clearance everywhere, but as I said, the drivers side collector is almost pointed strait down at ground. I wanted to keep everything tucked beside the frame rails.
Old 07-16-2013, 06:54 PM   #9
nw68
do you have a picture with the #68198 on the drivers side??
nw68 is offline   Reply With Quote
Old 07-16-2013, 08:29 PM   #10
ecgate
ecgate's Avatar
Im running hooker chevelle full length headers #2455. I have a bbc and running POL'S tubular engine and tranny mount. These headers couldn't fit any better in my opinion. Im running a 4.5" drop in the front and a 7" drop in the rear.
ecgate is offline   Reply With Quote
Old 07-16-2013, 09:38 PM   #11
BossHogg69
motor exploder
BossHogg69's Avatar
No, it was hitting the clamshell motor mount so it wouldn't bolt up. I was going to get a pic after I notched the motor mount ('72 BB clamshell style) but haven't messed with it yet. Other than the motor mount interference, there is plenty of room and lots of ground clearance.
Adam
Old 07-16-2013, 09:49 PM   #12
nw68
Old 07-16-2013, 09:55 PM   #13
nw68
im really new to this site, came across it and it seemed very informative. i cant figure out how to put pictures up yet... i built my own custom trans crossmember that is a fixed cross, but i can still unblot the tranny mount. i planned on the exhaust running in the middle of the height of the crossmember. the headman elite 68198 look like they would work closest to what i need, jus wondering if any headers were a lil higher?
Old 01-09-2014, 08:33 PM   #14
69SCSS
69SCSS's Avatar
Was wondering if you got the mount in and the other header. I'm pretty close to getting my headers and it looks like the collector might interfere with the trans linkage arm, so wanted to see if you had installed yours and maybe had a pic of it? Don't want to spend the money to have to return it!
Thanks, Al
My 68 SWB
Al Silveira Music
<- My daughter loves this guy 8-)
69SCSS is offline   Reply With Quote
Old 01-09-2014, 11:23 PM   #15
Willys47
Willys47's Avatar
Hooker Headers#520-2455-2
Competition Headers
396-502 Chevy Big Block V8
1970-72 Camaro
1964-74 Chevelle, El Camino
1970-74 Monte Carlo
1971-74 Full Size
2'' x 30'' Primary Tubes
3.5'' x 10'' Collector
Stainless Steel
these are what I have installed and they fit like a glove they run real close to the auto colum shift linkage so I had to use a lincage from a 1975 pickup
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 01-09-2014, 11:29 PM   #16
jeh
jeh's Avatar
Competition Headers
1970-72 Camaro
1970-74 Monte Carlo
1971-74 Full Size
Stainless Steel
pickup
What motor mounts did you use?
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 01-10-2014, 01:45 AM   #17
Willys47
Willys47's Avatar
the early style big block stands and mounts
Old 01-10-2014, 12:30 PM   #18
Fitz
Weev:
Like your truck, I lowered the front with 2.5 in drop spindles and 2" drop springs. Sanderson makes a set of long tube headers that actually fit our trucks! BB4 Blockhuggers. They stay ABOVE the bottom of the frame rails once they get past the wheel arch. A small (3/8 in deep) half moon in the upper flange of the frame on the passenger side was required to clear the #2 tube but that was very minor.
Fitz is offline   Reply With Quote
Old 07-19-2014, 01:38 AM   #19
BossHogg69
motor exploder
BossHogg69's Avatar
Here are some follow up pics for those wanting more info on Chevelle headers in a C10 - these are part #68198 (same as in the pics I posted above). You can see how tight the #1 tube is on the '72 style BB motor mount on the driver side and also where I had to notch the clamshell on the driver side, also for the #1 tube. As for the rest, it's a 3" Flowmaster universal kit that I cobbled together with Borla mufflers.
Adam
Old 07-19-2014, 10:37 AM   #20
SierraMtns
SierraMtns's Avatar
Originally Posted by Fitz View Post
Weev:
Man that 572 looks awesome.
SierraMtns is offline   Reply With Quote
Old 09-03-2015, 09:27 AM   #21
scoots71
scoots71 is offline   Reply With Quote
Old 09-03-2015, 09:28 AM   #22
scoots71
What trans are you using and shifting
Old 10-25-2015, 08:21 PM   #23
Average Joe
Average Joe's Avatar
Competition Headers
1970-72 Camaro
1970-74 Monte Carlo
1971-74 Full Size
Stainless Steel
Any pics of said linkage? Thanks in advance.-Brian
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
