06-11-2013, 08:47 AM | #1 |
I think my truck might be a numbers matching
Is there anyway to 100 percent sure. I ran the numbers on my block it says 283 out of a 1965 Chevy. My truck is a 1965 C10 any help would be appreciated thanks.
Posted via Mobile Device |
06-11-2013, 11:00 AM | #2 |
Never Ending Projects
Re: I think my truck might be a numbers matching
There should be a pad on the pass. side front of the block, right where the head meets the block. Typically there would be a stamped number there and part of this number would match part of the VIN number (like the last part). If these match up, this would be a numbers matching otherwise it would be date code match.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
06-11-2013, 11:38 AM | #3 |
The top drivers side of the frame near the motor mount has a number stamped on it that should also match the vin on the cab.
06-11-2013, 12:06 PM | #4 |
So here are my numbers
Cab C1445Z146996 Front of the head F0309GF Frame 5Z146996 Posted via Mobile Device |
06-11-2013, 01:16 PM | #5 |
Looks right to me
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
06-11-2013, 04:54 PM | #6 |
So your frame matches your cab vin. That's good!
Should be more numbers on the front pad. to be a match. Do you have a powerglide tranny? |
06-11-2013, 04:59 PM | #7 |
06-11-2013, 05:15 PM | #8 |
THe suffix code GF says it should be a powerglide. Originally. Probably swapped.
You need the 146996 on the pad for the match to your vin. |
06-11-2013, 05:24 PM | #9 |
I could be wrong but i dont think they numbers matched our years in trucks!you can only date match it.if you have buildsheet or spid you can prove that it came out of the box with a 283!also another matching serial number on the top of frame under cab!cheers
06-11-2013, 08:03 PM | #10 |
I thought numbers didn't match until 66. at least that's what I have read on here before
06-11-2013, 08:15 PM | #11 |
this is what you would have if you had matching nbrs. this is off my 64 4 x 4 panel
ron |
06-11-2013, 09:07 PM | #12 |
They weren't as diligent about numbers down here as they were up there Ron. They did not stamp vin numbers on 283's so your truck will only have the code.
06-11-2013, 09:24 PM | #13 |
I really don't know what it had orig for an eng. it had that 4 cyl in it when I got it. it would be neat though if one had the orig eng and if it did have that nbr stamped in it. the early chevs had then that way as my 32 chev tag was also the same way and did have the corresponding nbr stamped on the eng. the all had that at one time, don't know when they stopped it. mind you they never had the production nbrs up here that were down there.
but that would have been a true nbrs matching ron |
06-11-2013, 10:24 PM | #14 |
So what your saying is its almost impossible to see if its a numbers matching.
06-11-2013, 10:32 PM | #15 |
Without the build sheet it is impossible to know, that's why documentation is everything.
06-11-2013, 10:35 PM | #16 |
You could check the casting date. It should end in a 5. Here's a link to check it.
http://www.nastyz28.com/sbchevy/sblock.php |
06-12-2013, 12:55 PM | #17 | |
F0309GF F = Flint 03= March 09= the 9th GF= 1965 with a 283 power glide I'm not sure what tranny I have. I assumed it was a turbo 350. I guess I will pull the numbers and look it up. Things are looking better and better. Posted via Mobile Device |
06-12-2013, 01:35 PM | #18 |
Is the trans a 2, 3 or 4 speed?
06-12-2013, 01:45 PM | #19 |
06-12-2013, 01:48 PM | #20 |
You still need to check the casting date and the block casting number.
If it's a powerglide it should have a rod for the kickdown like in the first pic in this link. A turbo 350 uses a cable. Here's a link to determine what tranny you have. http://www.maliburacing.com/auto_tranny_id.htm http://67-72chevytrucks.com/vboard/s...d.php?t=523578 |
06-12-2013, 01:56 PM | #21 | |
06-12-2013, 07:40 PM | #22 |
How did you decode that motor because I have a 65 C10 with a 283 powerglide and it codes as a WE which in my manual is exactly right. I don't even see a GF anywhere in the factory manual for numbers.
06-12-2013, 07:49 PM | #23 | |
06-12-2013, 09:20 PM | #24 |
I am going right out of the chevy manual and I took the motor out still bolted to the powerglide so am 100% sure its right.
06-12-2013, 09:56 PM | #25 |
Well you see the facts I posted I don't know what to tell you.
