Old 06-11-2013, 04:27 PM   #1
chris1htx
Air intake in an inline 6
Can I see some pics or suggestions of an air intake for an inline 6. I'm looking to put something in my 84 c10.
chris1htx is offline   Reply With Quote
Old 06-12-2013, 06:22 AM   #2
andrewmp6
Re: Air intake in an inline 6
What kinda carb you got on it?You can go with just a normal air cleaner style or a tubing style http://www.spectreperformance.com/
andrewmp6 is offline   Reply With Quote
Old 06-12-2013, 06:31 AM   #3
D13
D13's Avatar
Nothing works significantly better than the factory air cleaner with the intake tube to the fender area. Assuming you have the integral head with 2-bbl staged carb, there is little or nothing in the aftermarket. unless you're buzzing this to RPMs that the rods won't like, the factory stuff, cleaned and painted, is pretty good. I did see someone who welded his base into a larger taller cleaner. You might also search Jyard for one from a big truck, just to be different.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 06-12-2013, 10:56 AM   #4
chris1htx
that is what sucks about having the inline 6, it's a very good engine but when you want to start adding some performance parts to it you are limited. i think i might end up switching out the carb.
Old 06-13-2013, 06:30 AM   #5
D13
D13's Avatar
You'll have to make your own carb adaptor. Off hand I know of notihng that's a direct replacement for the Varijet. You might be able to machine out the pocket on the integral head - no one I know has ever tried it but anything's possible.
1987 2 ton
Old 06-13-2013, 06:43 AM   #6
Unca
The old school circle track racers, used to run a 4 barrel carb on the straight 6 engines, there are cams, rods, cranks the whole 9 yards to build whatever you'd like out of your 6'er. That being said... the simplicity of dropping in a v8 makes the idea, unless your heart set upon it, a hard choice to make..(the old there is no replacement for displacement theory)
Unca is offline   Reply With Quote
Old 06-13-2013, 09:16 AM   #7
1981Stepside
1981Stepside's Avatar
I respectfully disagree sir. That's the beauty of theories. It's just a theory.
http://youtu.be/S7rCGda4Ab8?t=40s
Proud UA member since 2009
My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660
Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA
1981Stepside is offline   Reply With Quote
Old 06-13-2013, 01:43 PM   #8
INSIDIOUS '86
INSIDIOUS '86's Avatar
In theory adding boost is adding displacement lol. But a 1000rwhp inline 6? That will shut up those supra thumping kids haha
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 06-13-2013, 05:24 PM   #9
Unca
I agree, I also love the older motors, a flathead ford can be race tuned as well, but if you truly want to go fast on a budget.../shrug... a 6'er will go fast. but its not going be cheap. these old Chevy's have so many fun aspects, just like ice cream.. many flavors, for many tastes.
Mine is a big block, soon to be a little more healthy, but its hard to make a truck unique doing it this way.
I saw a 64 short bed last weekend with a Cummins in it.. it sounded AWESOME the guy had it setup as a land speed race truck, single exhaust outlet thru the passenger side front fender.. it was truly cool. and very unique. God only knows how much money n time he had in her.
I wasn't trying to sound negative, just realistic not many folks have huge budgets to play with on toys.../grin
Old 06-13-2013, 05:33 PM   #10
johnnyclack
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
http://www.summitracing.com/parts/of...make/chevrolet
If you want six, you can have
johnnyclack is offline   Reply With Quote
Old 06-13-2013, 10:37 PM   #11
Billy81
Billy81's Avatar
Since his is an 84 he will have to swap to an older head to be able to use that intake that is why most people junk the integral head you cant do much if anything with it.
Billy81 is offline   Reply With Quote
Old 06-14-2013, 09:30 AM   #12
johnnyclack
Thanks , I missed that point. I have no exp w/newer six's
J
Old 06-14-2013, 11:30 AM   #13
cyclefreak207
cyclefreak207's Avatar
Agreed... I got into building a lot of civics when I wanted fast cars and was on a hella tight budget, and they didn't have a lot of displacement... But this D*** SURE did the trick
86 Short Bed Build
I don't always downshift when I want to change lanes... But when I do, I make sure it's next to a prius so they know I'm hurting the environment!
cyclefreak207 is offline   Reply With Quote
