06-11-2013, 07:15 PM | #1 |
5 lug to 6 lug conversion
Hey guys. I searched and couldnt find anything. I have a 83 C10 stepside. Is it possible to convert it to 6 lug with axle and front suspension parts from a 88-98 truck? If so, what all would i need? Any help is much appreciated. Thanks.
06-11-2013, 07:18 PM | #2 |
Re: 5 lug to 6 lug conversion
No need for 88-98 parts. Use the common 'disc brake' conversion rotors for the HD 73-87 spindle. They're 1.25" rotors & come in 5 or 6-lug. The rear is as simple as swapping 73-87 4wd axles into the current 5-lug rear end.
06-11-2013, 07:22 PM | #3 |
Ok cool. So for the front, can i get these parts from the local yard or do I have to order from LMC Truck?
06-11-2013, 07:53 PM | #4 | |
That being said, most of the board supporting vendors can supply you w/the correct rotors to do the 6-lug pattern w/the 73-87 spindles. Go to the 'Suspension Marketplace' link @ the top of the suspension forum page. The rear axles would be a local yard type part....
06-11-2013, 08:27 PM | #5 |
Thanks Scoti. Much appreciated.
06-11-2013, 08:59 PM | #6 |
or just take your existing axles to a machine shop and have them re drill them to the 6 lug pattern.
06-11-2013, 09:02 PM | #7 |
ok i found the 6 lug rotors for the front but i cant seem to find the hd spindles
06-11-2013, 09:09 PM | #8 | |
67-72 parts collector,…
1" rotors or 1.25" wide rotors? Do you want standard or drop spindles? Everyone sells them.
06-11-2013, 09:53 PM | #9 |
06-11-2013, 10:39 PM | #10 |
Not sure there's enough material there to do 6x5.5" pattern.
06-11-2013, 11:42 PM | #11 |
06-11-2013, 11:43 PM | #12 |
