Old 06-11-2013, 08:55 PM   #1
YourBuddy'sTruck
YourBuddy'sTruck's Avatar
Brake and Axle Questions....Rear
Hey there.
This forum is the biggest help that I've ever had with any vehicle!
I've a C20 from 1970 (although I wonder about a LOT of parts!)
I need help idetifying my Rear End and Rear Brakes so that I know what parts to order.
The Rear End Cover has 14 Bolts.
The Wheels have 8 Lugs and also 8 Bolt Axle in the center.
Are these floating axles?
Do the Drums come off without removing the Axle?
The Drums sit/stand out 2 or 3 inches from the wheel on the inside. (nice design! I like it as it should run cool.)
My problem is twofold....
1 - The rear wheel cylinders are leaking brake fluid. So I have to replace'em.
2 - The Master Cylinder is tiny and completely manual! Horrible without a Booster!
I plan to add a new master cylinder/booster as $$$ comes in.
This is a heavy truck and I carry a heavy load, but only once a week for about 15 Miles as my delivery service for a local store. (up to 1 Ton).
So far, the help I've found here has me at just under $3K on this truck and I could not be happier with my basket case turned work truck.
Some front end and steering work had to be farmed out, but this forum has helped me keep a good budget, to say the least, and save my embarassment with dumb questions by just reading old threads.
I'm a total newb, but think that I may have an Old Chevy Truck larvea...not quite the "bug" yet.
Any help/advice would be greatly appreciated.
Cheers!
YourBuddy'sTruck is offline   Reply With Quote
Old 06-11-2013, 09:35 PM   #2
LONGHAIR
Re: Brake and Axle Questions....Rear
A 14 bolt cover makes it sound like a later model axle.
No, the drums will not come off with out removing the axles.
The full floater axles work very much like a front axle, with the hub/drum mounted to a hollow spindle. The only real difference is the non-turning part.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-12-2013, 07:59 AM   #3
YourBuddy'sTruck
Thanks. That confirms my thoughts.
